Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 245/35 265/30 E90 prelci ?
      05-05-2012, 08:54 AM   #1
pacyk
Drives: E90 pre-lci
hi guys,
I've bought recently a square set of ASA AR1's - they are 8.5 + 40
found tires (michelin PS2's)
245/35/19 and 265/30/19
will it fit?
got 20mm spacers for the rear if necessary
lowered on eibach prokit -30/25
any suggestions?
i'm afraid that fronts might rub while cornering
      05-05-2012, 09:22 AM   #2
bmw325i
Drives: 2006 BMW 325i
I wouldn't use 265's on an 8.5" rim especially if there ps2's.
      05-05-2012, 09:39 AM   #3
pacyk
Drives: E90 pre-lci
I know that 265's on 8.5 rim is way too wide but those ps2's are real bargain.
normally i would go with 235/35 all around
I just want to know if I will have any rubbing issues with this setup.
      05-05-2012, 11:04 AM   #4
Brian@bavarianx
Drives: E36 M3
No rubbing at all but I do agree that it is too much rubber for that size.
      05-05-2012, 11:53 AM   #5
pacyk
Drives: E90 pre-lci
thank you Lawrence
can I also run 20mm spacers on the rear ? (8.5 ET20 265/30)
      05-05-2012, 12:44 PM   #6
bmw325i
You might be able to. With the right sized tires it'll fit no problem.
