Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > BMW lugs are bolts or nuts?
      05-07-2012, 05:32 PM   #1
The Dez
Drives: LMB E93 M3
This will be the first time for me changing my OEM 189's to after market 19's. I have heard through the grapevine that BMW use OEM LUG "Bolts" not LUG NUTS. Is this true? Yes i know im gonna get alot of answer like "take it out and see what it is" Just wanted to know if I need to get a stud conversion to get my 12x1.5 "nuts" on? If so, what length stud conversion do I need to purchase to get my after market lugnuts on. Thanks for all the info you guys provide.
-Dez
Car info:
2008 335i E92
      05-07-2012, 06:04 PM   #2
ExpensiveTaste
Poor Kid with Dreams
ExpensiveTaste's Avatar
Drives: BSM 07 E90 335xi
-Dez
Car info:
2008 335i E92
Yes, they are lug bolts.
'07 BSM 335xi JB4, DCI, CX Racing I/C, ER Chargepipe, Meth, KW V3 - Pending Sale
'95 Mustang GTS 347ci Ported TFS TW Heads,Custom Cam,Victor 5.0 IM,Tubular Front Suspension,Full Exhaust,Big and Littles
      05-07-2012, 06:05 PM   #3
#Tee
#Tee's Avatar
557
Drives: yes
what color is your car?
You can follow my builds on IG: Tee212
      05-07-2012, 06:14 PM   #4
The Dez
Drives: LMB E93 M3
Thanks.. To make my new wheels fit, do you know what size lug conversion i need to make my lug nuts stick? i have 12x1.5 lug nuts.
Alpine white.. why?
      05-07-2012, 06:17 PM   #5
#Tee
#Tee's Avatar
557
Drives: yes
you dont be needing any "conversions" the oem bolts have the 60 degree taper. which is pretty standard on any aftermarket wheel.
      05-07-2012, 06:50 PM   #6
MRRwheels
Drives: E92
same factory Bolts will do for aftermarket wheels.
your good.
      05-07-2012, 07:11 PM   #7
The Dez
Drives: LMB E93 M3
Sounds good didnt know the OEM bolts has a taper (acorn/spline). Well for future reference, what stud length do I need to fit some project kics or T1R spline drive nuts? Im not looking for extended just OEM 12x1.5 fit.
      05-07-2012, 07:31 PM   #8
#Tee
#Tee's Avatar
557
Drives: yes
57 is the oem replacement size, if you goona run a open ended kics/t1r nut then most likely it should be a 75mm stud naamean?
      05-07-2012, 11:27 PM   #9
michael1284
michael1284's Avatar
210
Drives: 2018 M3 Comp
Like stretch I ran 75 mm on my e90 and e92. Sits like 1/8 inch past the lug naaaameannn
e92, e90, f30 #DieselLife, e46, f80
