Sirius problem fixed w/ software update
06-25-2007, 10:52 PM | #1 |
Rep 959
I had my sirius module replaced today and software updated, symptoms included:
1) no satellite functionality at all, indicated I didn't have a subscription and needed to call Sirius to subscribe. Requires that car enters sleep mode (5+ minutes parked and locked and shut off) to have a chance to fix. 2) all satellite presets going to "Hits 1" (channel 001) when getting in the car. Resolved by turning off car and turning it back on. FM/AM presets working fine when this happens. The final report states I went from 89X-06-12-510 to 89X-07-03-521, and that reprogramming went along with the module replacement to address the issue. Anyone know what "Progman" versions these two codes describe? Also, the SIB in question is "SIB 65 07 07" relating to the Sirius module, but I can't find any information for this one online. Lastly, I noticed with the new progman, my dash fonts changed, especially noticable with the "degrees F" symbol... (non-Idrive) and it also appears I new get the FM radio channel information on the center console? Not sure if I had that before, I listen to FM so rarely... --gos
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC |
06-26-2007, 09:29 AM | #2 |
Rep 95
gos - thanks for this post ! I have been reporting the problem with No service for a year now - but because it is intermittant, it never seems to do it for the Service Tech. I've gone as far as to drive it directly to the Dealership several times when this occurs - so now having the SIB number may make some headway with getting them to fix this for me. Glad it got fixed for you.
2006 330i Sparkling Graphite/Gray Leather * 6MT * zPP * zSP * Sirius * OEM Spoiler * Fold-down Rear Seats * Lo-Jack * Pinnacle 35 FormulaOne Tint * Blackline Tails *
06-27-2007, 01:12 PM | #3 |
Rep 959
Sorry to bump, but does anyone know what these two codes refer to in "Progman" terms? Googling on them doesn't give an exact match.
06-27-2007, 09:50 PM | #4 |
20
Rep 374
Drives: '05 645Ci Coupe
SI B 65 07 07
Sound System, Cruise, Alarms, Monitors April 2007 Technical Service SUBJECT SDARS SIRIUS Radio is Intermittently Inoperative MODEL E90, E91 *(3 Series) E92, E93 *(3 Series Coupe/Convertible) E60, E61 *(5 Series) E63, E64 *(6 Series) *Only with option 655 (SDARS Satellite Radio) SITUATION When the SIRIUS Satellite radio is intermittently inoperative, the following can occur: The SIRIUS radio preset list is empty "Call SIRIUS" is displayed to subscribe CAUSE Incorrect hardware and software in the SDARS Satellite module, GEN2.5 (Generation 2.5) CORRECTION Try to reproduce the complaint, when possible with the customer. If it can be reproduced, immediately call SIRIUS to verify that the subscription is not deleted or outdated. When the subscription is verified and the module can be recognized by SIRIUS, remove the SDARS module and check the part number on the module. When P/N 65 12 6 987 545 is installed, create a PuMA Case for parts replacement authorization and include the following information: Part number of the SDARS module Hardware number Software number ESN number Install an improved SDARS module and program the vehicle with Progman V25.01 or higher per SI B09 05 01 (Coding, Individualization, Programming), Procedure A. Important: Complete vehicle encoding has to be done as outlined in the procedure! PARTS INFORMATION Part Number.............. Description..................... Quantity 65 20 9 142 850... SDARS Satellite module GEN2.5...1 WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code Refer to KSD Labor Operation: Refer to KSD Labor Allowance: Refer to KSD And from my posted list (elsewhere on forum - you have to search): Released 6 May on Centernet - First reported on 22 May 07 E90/91/92/ 93 Progman 25.02.00 = (Target data Status E89x-07-03-525). 3/7/2007 (posted on TIS ~ 22 April) E90/91/92/ 93 Progman 25.01.00 = (Target data Status E89x-07-03-520). So you are in between: Has to be: 25.01.01 You used to be on 24.00.00 (TDS E89x-06-12-510) |
