7th Injector?
05-14-2012, 02:25 AM | #1 |
56
Rep 329
7th Injector?
Has any one ever thought about running a 7th injector to our car? Since our fuel system seems to have a limit with big power..
I have a few friends who have Cobolt SS' that have the GM's LNF motor. From what I have heard and minor research I have done.. These motors are some what similar to the n54. Direct Injection, cam driven fuel pump, turbo charged and etc.. They also have similar restriction's as we do - the biggest is the fuel system being tapped out. So what I've found out is they add a standard fuel 5th injector to there car right before the throttle body I believe.. correct me if I am wrong. So if any one out there has any comments about this or theory how this might work.. post up.
24 XM(Current)
22 X540i(Sold) 21 M5 Comp(Sold) 07 Single Turbo 335i(one of the first, sold) |
05-14-2012, 07:05 AM | #2 |
Rep 462
yeah basically like meth injection but with fuel a cheap fix.. the right thing to do would be a new intake manifold with secondary port injection or figure out a way to upgrade the current pumps since i believe the current injectors are not maxed out yet
Irub |
05-14-2012, 07:35 AM | #3 |
Some dude
92
Rep 1,780
HPF already has a manifold with 6 more port injectors if you want more than the 644RWHP of the Vishnu kit. Even there, the Vishnu single is still running with plenty of fuel with what we speculate is just a low pressure delivery pump upgrade on stock injectors and stock HPFP. Yes, he does run a good bit of methanol, but still under 1500cc/min for cooling of the intake charge. High IATs will kill a high boost motor just like high AFRs.
RRT
E92 335i/6MT with stuff and things |
05-14-2012, 09:30 AM | #5 | |
103
Rep 3,177
05-14-2012, 10:05 AM | #6 |
Some dude
92
Rep 1,780
That's what Lexus does on their DI motors - they have extra port injectors to wash the valves off under certain driving conditions. Or at least that's what I've heard.
RRT
05-14-2012, 10:12 AM | #7 |
56
Rep 329
Great points every one , with the port injection - that sounds like a good idea. As far as meth - I am just trying to avoid the meth discussion and find an alternative more solid solution.
24 XM(Current)
05-14-2012, 11:46 AM | #11 |
3441
Rep 79,211
I have but I'm not sure its relevant to someone looking to avoid hitting a fuel limit if they are already hitting a fuel limit on pump gas. It still doesn't get away from the fact that e85 alone requires up to 30% more fuel. So if one is hitting a fuel ceiling then e85 would not be the answer is all I'm saying as it requires more fuel then regular pump gas.
05-14-2012, 12:34 PM | #13 |
56
Rep 329
lol I know all about the e85 stuff - use a 60/40 mix on my car.
24 XM(Current)
