kinda dumb question but i need help!
06-28-2007, 09:50 AM | #1 |
Rep 2,458
ok i have the AUX input and an ipod, i want the iod to play thru the car's stereo, i dont need the abilityto change songs and stuff thru the car, i can do it thru ipod so i need to buy this wire just to connect the two. does such a wire exist, what is it called, and where can i buy one?!
06-28-2007, 09:54 AM | #2 |
Rep 1,100
So, you do not have 6FL correct? If not, you can connect a usb/usb connector to the aux output and to your ipod cable. Like you said, it wont allow you to integrate the functions of the ipod, but you should be able to listen through the stereo.
[FONT="Garamond"]2007 E90 335 xi, Monaco Blue, Beige, Prem, Cold, Step, Navi, Sat, iPod
06-28-2007, 10:23 AM | #4 |
Rep 86
I got this about two weeks ago. Works like a charm!
http://www.amazon.com/Ipod-Dock-Conn...044126&sr=8-42 |
06-28-2007, 10:35 AM | #6 |
Rep 2,458
hmm i dont think i need the charger just the aux cable, where can i get that? bestbuy? staples?circuit city? walmart? lol im just naming a bunch of stores that around here hah
06-28-2007, 10:39 AM | #7 |
10
Rep 358
I use the monster charger. It plugs into the power socket in the arm rest and you need a separate 3.5mm jack male to male to lead which connects from the line out (on the monster cable) to the aux in in the car. Your iPod charges when your car is running and the iPod is automatically turned off when you turn off the car.
Also if you have a wired remote for the iPod then what I do is dangle the end of this out of the arm rest and then close the arm rest and then I can easily play/pause and skip tracks withough having to open the arm rest and fiddle with the iPod. |
06-28-2007, 10:54 AM | #8 |
Rep 55
you just need an AUX mini stereo male to male plug. plug it into the headphone jack of the ipod and the AUX input in the armrest. the sound quality of the headphone jack output is slightly lower than pulling the audio out of the dock connector at the bottom (which is what the monster adapter things do) but this way is cleaner and cheaper. The Ipod will not charge, but the battery should last a good long time. Just remember to turn it off when you get out of the car. I did this for years in my e39, and it was great.
e90 335i - Arctic Metallic/Black/Sport/6MT
06-28-2007, 12:03 PM | #9 | |
Rep 2,317
06-28-2007, 06:52 PM | #11 | |
Rep 143
