BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Aux Input Removal
      11-07-2005, 08:24 AM   #1
nexus66
Drives: F80 M3
Aux Input Removal
Any of you guys know if it's possible to pop out the aux input jack without removing the whole centre console section??
I ask because my car keeps dropping the left channel when using my ipod. I've tried 2 different cables and it does it with both! Tried the cables on my home stereo so it's not them!
It's already been in to the dealer and they failed to fix it - so if it wasn't too difficult I'd have a look at it myself. I reckon it's probably a loose connection in the actual jack itself!
Drives: BMW F80 M3 - Sahkir Orange
      11-07-2005, 09:30 AM   #2
cdxp
Drives: 325 Saphire Black
I reckon the dealer should be able to fix it ! - are all the dealers everywhere this bad ??
      11-07-2005, 10:41 AM   #3
nexus66
Drives: F80 M3
The dealer has already had a go and told me it was fixed! That's why I thought I'd have a go...
      11-07-2005, 10:44 AM   #4
uofmtiger
Drives:
The cable has to have a 3.5mm tip. If you can pull the tip out a little and it works, you probably are not using the proper cable. I had the same problem with cables I already had laying around that work fine on my Tivoli radio aux input, but the car's input is more choosey.
I bought a Belkin 3.5mm cord and it works fine.
      11-08-2005, 10:07 AM   #5
nexus66
Drives: F80 M3
Well - the plot thickens!!! I was able to remove the rear panel where the rear air vents are and found the cables for the aux input! Lo and behold one of the cables is all pinched and actually burst through so that I can see the wires!! Looks like this is the problem!! :mad: :mad:
Dealer is going to fix it this weekend!
      11-08-2005, 11:28 AM   #6
Kimo
Drives: E31 E90 F25 MCS
So . . . what exactly did your dealer DO the first time around? Pathetic.
      11-08-2005, 11:52 AM   #7
nexus66
Drives: F80 M3
Cos it was an intermittent problem, they probably stuck an ipod in went "oh - it's working" and gave me it back!!! Worst of all - they caused the problem when the dash had to be removed to fix the air-con!!!!!! The only word I can use for the dealers mechanics is INCOMPETENT!!! Menzies of Stirling btw...
      11-08-2005, 12:31 PM   #8
Kimo
Well I certainly won't be taking my wife's car across the pond to Scotland for service at this dealer
      11-09-2005, 08:41 AM   #9
nexus66
Drives: F80 M3
Can I bring mine over the pond to your's for a service??
      11-09-2005, 08:44 AM   #10
rag21
lets drink
Drives: 06 E90 325i
i'll bring your car over for those wheels and head lamps
There's no place like 127.0.0.1
