TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Scan Tool
      06-08-2012, 05:20 AM   #1
GT1
Drives: 335i
Scan Tool
Hi,
Can anybody recommend a scan tool (make and model number) to check and re-set fault codes?
Can you check and re-set fault codes through the iDrive system on a 335i?
Can you re-set service schedules through the iDrive or do you need to do it through the OBDII port?
Thanks.
      06-08-2012, 05:26 AM   #2
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
Mrtanz or luster are the coding gurus
      06-08-2012, 05:43 AM   #3
luster
Drives: e90, e88
indeed we are. i can do all that for you
you can also buy a BT TOOL if you really want to do it yourself.
      06-08-2012, 06:35 AM   #4
GT1
Drives: 335i
Hi Luster,
Does the BT TOOL let you scan for fault codes and re-set them and re-set service schedules?
Where can you buy them?
How much do you charge for fault code checking and re-set service schedules?
Thanks.
      06-10-2012, 07:09 PM   #5
WOPALX
WOPALX's Avatar
Australia
86
Drives: 335i Sedan
BT tool is great, I have one for sale here;
http://www.e90post.com/forums/showthread.php?t=676298
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
      06-10-2012, 07:27 PM   #6
michaelalex17
michaelalex17's Avatar
596
Drives: Manual Wagon
BT scan tool FTW!!
      06-10-2012, 07:51 PM   #7
cwarren
cwarren's Avatar
82
Drives: 08 e92
can you code injectors with the bt tool ? looked through the options and did not see it there.
thanks guys!
      06-10-2012, 10:26 PM   #8
luster
Drives: e90, e88
injectors with coding cable / inpa
