Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > External Hard Drive
      07-06-2007, 05:21 PM   #1
mrringodi
Drives: e90 M3
External Hard Drive
Was wondering if it is possible to use a 40GB usb external hardrive with mp3's with the 6FL ipod USB adapter.
      07-06-2007, 07:43 PM   #2
AndreTheGeek
AndreTheGeek's Avatar
16
Drives: 335i E90 Alpine White
My Western Digital Passport 120GB drive does not work. It spins, and the light blinks, but the car says it's empty.
I also tried a 2GB microdrive with a USB adapter, and it gaveme an error. (CF cards work though).
Try it and let us know if it works.
      07-06-2007, 07:56 PM   #3
msimon18
Retired
msimon18's Avatar
Drives: Z4 s30i
My Archos AV400 works fine --- just like a USB thumb drive -- similar menus
M3 GTR - 1/5 scale - 4.2 HP w/ Collari hydraulic brakes - would you believe ~80 MPH on straightaway !!
      07-06-2007, 08:43 PM   #4
drwtsn32
drwtsn32's Avatar
Drives: 2014 BMW 435xi, 2016 MB GLA250
How is your drive formatted? If it's NTFS, that would definitely make it not work. Try formatting it FAT32 and see if it works. It would be awesome if these Passport drives would work!
      07-06-2007, 08:47 PM   #5
T Bone
T Bone's Avatar
532
Drives: 2008 335xi Coupe
+1 Yes, this is in the manual..... You need to format the media with PHAT, I mena FAT. Also I think the other issue is the 6FL port may not be 100% USB compliant and supply the necessary power.
Let us know if this works!
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
      07-07-2007, 01:29 AM   #6
nhhiep
Drives: bmw
Just to let you guys know that power coming a USB won't be enough to spin any external drive that uses 3.5" HD. with 2.5" or 1.8", it should work.
      07-07-2007, 05:09 AM   #7
BMW320DA
Norway
Drives: 525XD CIC 2009
guys I hope you can try the Fat32 on a 2.5" hdd
my PNY 4gb memory stick works, allthough a bit slow when changing songs.
      07-07-2007, 07:39 AM   #8
AndreTheGeek
16
It is FAT32. Just doesn't work.
      07-07-2007, 08:14 AM   #9
drwtsn32
drwtsn32's Avatar
Damn..
      07-07-2007, 11:11 AM   #10
zenmaster
Drives: '17 M2
In addition to power output limit, there could also be a limit on storage size. The Archos AV400 could've worked because it has a battery and is only 20GB.
To rule out the power output limit, you could try using a cigarette-lighter power invertor ($25) to power the external drive. (But some USB drives don't have seperate power supplies)
      08-08-2007, 11:14 AM   #11
nub340
nub340's Avatar
Drives: 2009 335i E92 M-Sport 6MT
I'm using an External 40GB Firelite Bus-Powered USB drive formatted FAT32 with about 16GB of music on it so far, works fine, well kinda. First of all, the first time I connected it, it took over 30 MINUTES!! for the "Directory" category to finally became available. Then another 30 minutes for the other categories to become available (Artists, Album, Genre, etc). Once it completed the initial indexing, the "Directory" category becomes available fairly quickly (within a minute or 2), however the other categories still take about 5-10 minutes to become available.
R135 │ 2009 335i E92 6MT / LeMans Blue / Black Dakota / Gray Poplar
└┼┼┤ │ Premium / M-Sport / Nav / HD / PDC
.246 │ Heated Seats / iPod+USB / Smartphone Integration
