Clean engine bay?
06-26-2012, 11:35 AM | #1 |
Rep 1,326
Clean engine bay?
How people,
wondering how or if you guys clean your engine bay? I usually just wipe it a cloth after each car wash. That's it, no products etc. This is how it looks so far. Mind you the last two times I washed the car, I didn't have time to wipe it. So bit dusty. Have some stubborn water marks and some oily bits. Not sure how to get rid of them. |
06-26-2012, 12:13 PM | #2 |
Rep 636
That metal bracket on the left that holds the blow off valves looks a bit rusty like mine. When I open the bonnet my eye is always drawn to it.
I think I might whip it out and spray it. Apart from that it looks nice and clean. |
06-26-2012, 05:04 PM | #7 |
Rep 1,326
I find that if I did it every time, it's much easier than trying to scrub off really dirty bits. But been too busy the last two times with all the MOT failing, tyre fitting and holiday planning.
The bit that annoys me the most is that thing with the green ring around it? Weird oily crap on it. Difficult to clean and that stupid air in take plastic thing with those tiny gaps in between. Guess no one here would use those "engine cleaner" spray on and wash with water technique? |
06-26-2012, 06:38 PM | #8 | |
Rep 463
I use APC and agitate pressure washer off then simply spray everything with 303 Aerospace Protectant and leave overnight. |
06-26-2012, 08:59 PM | #9 |
Rep 1,326
I really want to do that, but looks and sound scary doing that.
I mean like the headlight covers for instance, they come off so easily and not rubber sealed. Wouldn't it be bad if it got wet and all the other cables inside the engine area? |
06-27-2012, 01:06 AM | #10 |
Rep 463
Just be sensible where you use the power washer. Its all sealed well. Use high pressure rather than low too. Search in detailing world - plenty of threads there on BMWs from the professionals.
06-27-2012, 01:45 AM | #11 |
Rep 533
Drives: F15 X5 40d M Sport
06-27-2012, 11:42 AM | #13 | |
Rep 463
BMW electrics are well sealed. The theory is that on low pressure more water is used and can soak in. On high pressure the water is more finely misted and blasts the stuff away. Just be sensible where you aim ie not directly on to any sensors. As long as you do not just use a hose which would flood the engine I do not suppose it matters much. Personally I use both settings. |
