(E85)--Something that has me thinking...
07-13-2012, 12:33 AM | #1 |
Rep 6,136
First off, let me make it clear that I never plan to do the following, but:
Theoretically, could one fill up with 87 octane regular fuel, and mix in e85 gas for extremely low cost 93-95 octane? To me it would make sense, the user running a tune of course. Opinions please... |
07-13-2012, 12:37 AM | #2 | |
125
Rep 2,172
Sure, why not. Although all the tunes for e85 are based off 92 and not 87.
07-13-2012, 12:41 AM | #4 |
50
Rep 1,677
Drives: 14' GMC Terrain SLT-2
87?
Read my thread http://www.e90post.com/forums/showthread.php?t=696472 And also see dfv2 post and links pg. 2 Edit ....Read your post wrong... NM.
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
07-13-2012, 03:05 AM | #5 |
Rep 3,262
I think it would work.
07-13-2012, 06:49 AM | #6 |
Rep 575
Yes, but your 'ultra low cost fuel' would lower your fuel mileage. e85 has less energy per gallon therefore needs to burn more in order to get the desired effect. Doing this would do little to nothing in terms of money saving.
07-13-2012, 07:16 AM | #7 | |
Rep 233
07-13-2012, 09:31 AM | #10 |
79
Rep 2,396
Drives: '08 E90 335i
E85 lowers MPG & Regular Gas would be an awful base. You'd have to blend in more E85 to compensate for the lower octane rating of 87 instead of 91, so you'd be putting more E85 into your car (costs less, but more MPG = more trips to the pump).
Using an octane calculator & targetting a "home-made" 94, you'd have to mix ~9 gallons of 87 + ~7 gallons of E85. IMO, this would be WORTHLESS. The whole idea of using E85 is that you get an octane that is closer to Race Gas (100 octane) -- a 50:50 blend of 91 + E85 gives you 98. Stick to what the majority are doing, run some combination of 91/E85 and aim for an octane that's closer to 100. |
07-13-2012, 09:33 AM | #11 |
Rep 1,244
Here's a really good read on Ethanol, it explains that E85 isn't a "true" 105 octane. For those without patience, scroll to page 29 of the article:
http://ethanolrfa.3cdn.net/dd9e74ce1..._rbm6bdgh3.pdf ***EDIT*** This isn't to say it doesn't have cooling effects and that our engines won't like it...just the opposite. It merely points out that technically, E85 doesn't have an octane rating of 105 even though it may "act" like it does. |
07-13-2012, 09:59 AM | #14 |
79
Rep 2,396
For anyone who's looking for E85, this website seems to have the most updated & accurate listing (even lists govt./private gas stations )
http://alternative-fuel.findthedata....a/Ethanol-(E85) |
07-13-2012, 10:00 AM | #15 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
If you want to save money on gas get a Prius hippy
07-13-2012, 10:00 AM | #16 |
Rep 1,039
