Concerns with buying a used JB4?
07-27-2012, 01:14 AM | #1 |
Rep 29
Sorry if this question has been answered elsewhere. I STFA without seeing any discussion on this. I've seen a number of JB4s available in the classifieds forums, and I'm wondering if there is any cause for concern in purchasing a used kit as opposed to a new one (assuming the used kit is in good condition without bent pins). I'm coming from the B5 Audi side of things where we didn't do piggyback units, we just swapped entire ECU boxes. I just want to make sure there's nothing I'm missing!
Based on what I've read, it sounds like people rely a lot more on support either from Terry or the forums when installing something like the JB4. In my other cars, it was literally a 5 minute ECU swap and you were done- no thrown codes or dealers seeing data stored on high boost levels. Hence why I'm hesitant. Thanks for helping a noob out! |
07-27-2012, 01:23 AM | #2 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
No inherent problems with doing that. One of the very first things I bought was a used JB4 on this forum. Just follow the standard rules when buying used stuff, use your best judgement: be very specific with any questions you have, ask for recent pictures (with a date if necessary), use Paypal and ask for some kind of feedback.
Also, if it doesn't come with one, you'll want the USB cable to keep it updated and log runs. Installing it is very easy, if you need help - I'm in the Bay Area. I installed and removed mine a few times before switching, and I've been in the ECU area numerous times.
The i8 needs a V8 amirite?
07-27-2012, 02:00 AM | #3 |
Rep 868
Jb4's are not vin locked, I don't think Cobb is either
There is no additional cost to unlock it......Maybe that's why you see more forsale. Buy it and install, but I would go to n54tech, read up on it and like op said get a USB cable. I love mine Gl, R
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
07-27-2012, 04:37 AM | #4 |
Rep 7,377
Make sure you get the pnp version and not pinout.
07-27-2012, 09:24 AM | #5 | |
28
Rep 457
-Make sure pins aren't bent. -No wires cut or butchered during meth or dpfix install -make sure board isn't ruined from a botched ohm mod from soldering You won't know if the jb4 is good until its fully installed in your car so it's best to use PayPal and visually inspect it before purchase. USB is a required part. Don't know why it's considered an accessory. |
07-27-2012, 09:57 AM | #6 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
07-27-2012, 10:01 AM | #7 |
Rep 1,054
jb4 is the piggy. The harness could be a pinnout or a PNP. I run jb4 with my pinnout harness, no problem. Just messy in the ECU box and harder to remove for service. If you are out of warranty and plan to keep jb4 as your tune indeffinatley, pinnout is fine.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
07-27-2012, 10:05 AM | #8 | |
28
Rep 457
USB, It should be required. You can't adjust 60% of the settings without it. Like you said you can't log and you cant update. So it's like having half a product. USB is required. |
07-27-2012, 12:08 PM | #9 |
Rep 1,054
my pinnout allows for usb, logging, steering wheel control... all of it. Not the best option for someone looking for a tune but may be a cost effective option as the pnp harness new is $180
07-27-2012, 02:33 PM | #10 |
Rep 29
Thanks for all the replies guys!
@skinrock, thank you for the offer! I'm fairly handy with this stuff, but will ping you if I run into any issues. |
07-27-2012, 06:02 PM | #11 |
<3 Flat Four
217
Rep 754
actually, cobbs r, for a lack of better term, "vin locked" to the car, once the handheld programmer is used to flash a car, that handheld programer can only be used to flash that car only unless u remove the entire tune off the car, then it can be used on another car.
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White |
07-27-2012, 06:12 PM | #12 |
Rainbow Racer
1008
Rep 2,540
The main benefits of buying a new JB4 unit from Terry is that it'll ensure that you'll get a G4 15ohm board (which is a quicker board with lower cycle duties up to 19-19.5psi and will be more consistant with boost targets) vs. a G4 18ohm board. Plus, when you buy new, Terry always has sweet deals for new purchasers for future upgrades (such as his current $50 program for a big turbo JB4 G5 board vs. paying $150 for "used" purchasers) so the initial price advantage buying new washes away if you plan to upgrade in the future. Regardless of how you purchase his product's, new or used, his support and technical assistance makes you never left in the cold.
Also, welcome aboard, I'm from a B5 s4 and B6 s4 background too
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 Last edited by spool twice; 07-27-2012 at 06:18 PM.. |
