Studio RSR
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Turbo Engine / Drivetrain / Exhaust Parts > jb4 two pins missing. Will it work?
      07-28-2012, 04:07 PM   #1
MasterWang
Drives: F06 M6
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
I just bought a used jb4 from a member here...I just received it today and it is missing 2 pins (2 & 15). He is saying that it should still work perfectly without those two pins, but then why are all the other jb4's I've seen not missing these two pins. Someone please chime in and help me out here. Is it even "Safe" to install this jb4 with the missing pins?
      07-28-2012, 04:13 PM   #2
iBoost
Retired e90post Member
iBoost's Avatar
135
Drives: real slow
email terry! i doubt its safe
      07-28-2012, 04:23 PM   #3
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
most likely an older harness, email terry
      07-28-2012, 11:33 PM   #4
e90TiAg335i
e90TiAg335i's Avatar
Drives: 10 e90 335i
2010 e90 335i  [7.00]
2 is not used and 15 is only used for meth failsafe input. It is safe to use as is.
JB4, DP, VMR V710, Sonic Tuning S1 coilovers, Hybrid Ovations, Soundsplinter 10" and Zapco DC Ref amps
      07-29-2012, 01:01 PM   #5
Randomaccess335
Randomaccess335's Avatar
69
Drives: 07' 335I
FSB "Type B" N54 Wiring:
1) Remove the JB4 control box from the AMP connector and remove the two screws holding the AMP connector together. Upon removing the case you'll insert the FSB orange wire in to position #2 and the blue wire in to position #15. These will be the only open slots in the connector. They are numbered on both the front and back so check before pushing the pin in. If you lock the pin in the wrong spot by mistake you will need to go to Radio Shack or an electronics store to get an inexpensive tool called a "DSUB pin removal tool" to extract the pin and place it in the right slot. If you manage to damage a pin you can replace it with any male DSUB pin.
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets,
Ebay 4" chrome Tips, Lux Angel Eyes
**********11.910 @ 117.09***1.851 60'**********
      07-29-2012, 11:08 PM   #6
e90TiAg335i
Drives: 10 e90 335i
There you have it, not needed!
      07-30-2012, 11:07 AM   #7
scorpnaz7
Drives: 335i
Mine looks just like yours, it did not come with those 2 pins.
