08-01-2012, 01:45 PM | #1 |
Rep 235
What's up guys!
Got my car fully paint corrected and then coated with Opti Guard about two weeks ago. Haven't seen to much info on this forum about it so just wanted to put my .02 in. AMAZING! Having a Jet Black car it only took 2-3 washes (proper two bucket etc) to start seeing light swirl marks and other marring. This is the most PITA paint I have ever had on a vehicle by far! Something had to be done. Enter Opti Guard..... My detailer had been telling me about it for a while so I finally pulled the trigger. It's a great product. Water beading/sheeting will freak you out the first time you see it. Nothing seems to cling to the coated finish at all (dirt, grime, brake dust). Have washed it twice since being coated and it is literally spotless after the initial rinse. Quite incredible. The coating is also supposed to make etching from contaminants out of the question. But time will tell on that one. Best part is there is no need to wax or seal because they will not bond to the Opti Guard. So only thing needed are basic washes, maybe a quick detail spray for added gloss, and tire shine. Cuts down on cost big time. Overall I am very pleased so far. If anyone has any questions let me know!
2012 535i Jet Black M Sport 2011 335i Retired 2008 Range Rover SC Last edited by jenks89; 08-06-2012 at 11:58 PM.. |
08-01-2012, 03:38 PM | #2 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
yes, how much did the Opti-guard portion cost not the paint correction part.
08-01-2012, 03:49 PM | #3 |
Rep 8,772
I have a tube of this stuff ready to put on my F10. Just waiting for the car to arrive.
Did a lot of research about it and its simply amazing. I've seen a video where someone put optiguard/coat on half his car and after 2 years without any waxing or anything the coating was still beading water like day one. I plan to apply it to my F10 the same day i pick it up! Alan
08-01-2012, 09:26 PM | #4 | ||
Rep 235
2012 535i Jet Black M Sport 2011 335i Retired 2008 Range Rover SC |
08-01-2012, 10:17 PM | #5 |
Rep 1,346
Correct. Opti Guard is the professional version sold to detailers. 2.0 is the consumer version. I'm told it's the same product though.
08-02-2012, 05:10 AM | #6 |
Rep 1,207
Opti-Coat and Opti-Guard have the same life and protection.
The key difference is curing time; OptiGuard cures very quickly while OptiCoat is more forgiving. You have to be very efficient in your application process (doing it right first time, minimum residue) with OptiGuard as it bonds very quickly; while OptiCoat allows you time to spread the coating. This is the main reason OptiGuard is only available to professionals. Once applied properly; they both offer the same benefits.
08-02-2012, 08:28 AM | #7 |
Rep 8,772
Yep i have the Opti Coat 2.0 ready to go on. Already coated my new wheels with that stuff and just need the car to arrive.
I was also told you can top opti guard/coat with optiseal to make the finish look alittle more wet and more slick. Optiseal is a breeze to put on since it spreads over the paint like oil and it just flashes away on its own. I can do the entire car in no joke less than 10mins. 5 if i really want to rush. Alan
08-02-2012, 08:33 AM | #8 | |
Rep 235
08-02-2012, 08:37 AM | #9 |
Rep 8,772
Its not needed and it does not offer any extra protection but it does add alittle more shine and makes it more slick to touch. Thats what the optimum owners told me when i asked the question online.
Alan
08-06-2012, 11:48 PM | #10 |
Rep 235
updated with a pic of the hood after a rain tonight. This is what the entire car will look like. Glass, trim, and all!
08-06-2012, 11:49 PM | #11 |
Rep 235
thanks for the tip...just ordered some!
08-07-2012, 02:03 PM | #13 | |
Rep 235
If you're anything like me you'll be so relieved to get the opti guard done on your JB.
08-07-2012, 05:14 PM | #14 |
113
Rep 332
I am probably just like you when it comes to my paint. I have more detailing products than I would like to admit. This seems like a great solution. Setting my appointment for next week.
How is the gloss? |
08-07-2012, 09:57 PM | #15 | |
Rep 235
Took this the day after I had it done. Just an iPhone pic.
2012 535i Jet Black M Sport 2011 335i Retired 2008 Range Rover SC Last edited by jenks89; 08-07-2012 at 11:00 PM.. |
09-01-2012, 06:59 PM | #16 |
Master Of My Domain
89
Rep 669
I've got a Jet Black 550 that is a magnet for fine scratches - even with the high dollar microfiber towels. Does this lessen the scratching any?
09-01-2012, 09:14 PM | #17 | |
Rep 235
09-09-2012, 07:06 AM | #18 |
Rep 8,772
I applied the opti coat on my F10 and it works wonders on my space grey paint and wheels. Everything seems to stay cleaner WAY longer than pre treatment. Like Jenks said even when its dirty it still somehow looks clean like you can still see the gloss behind the dirt. Highly highly recommended!
If you can wax your own car you can probably apply opticoat 2.0 yourself. The key is to: 1. Do all paint correction work first 2. make sure there is zero wax on the paint (alcohol wipe down or Dawn wash) 3. wrap the yellow applicator with a latex glove then wrap the latex glove with the applicator inside with a blue shop towel with the smooth side facing out. (if you apply the shop towel on your paint and theres alot of noise you are using the wrong side of the towel) This prevents too much product to get sucked into the yellow pad and i find the blue shop towel glides over your paint much much easier than the pad alone 4. have some microfiber towels ready to go over the paint after the optic coat if you notice areas where it still looks hazy after 5mins of applying. You have about 10-15mins to still wipe down the product before it bonds completely. Work one panel of the car at a time and move on to the next. 5. Make sure you have adequate lighting to be able to see the paint 6. Do NOT use this product in direct sunlight or on a hot surface. I did my car at night with floor lamps shining around the car. One tube should be plenty enough to do your F10, 4 wheels and still have some left to do a small car with this method. Alan
09-09-2012, 07:46 AM | #19 |
Rep 67
If the applicator is inside the latex glove , how is the product getting to the yellow applicator. I am confused.
Are you using the shop towel as the applicator ?? |
09-10-2012, 07:05 PM | #20 | |
Rep 1,346
http://www.autogeek.net/optimum-dual...pplicator.html
09-10-2012, 10:58 PM | #21 | |
Rep 400
Thank you. |
09-10-2012, 11:42 PM | #22 | |
Rep 8,772
The blue towel method was much easier for me on my F10 Alan
