Plasma coils on 335i or other
07-16-2007, 02:32 PM | #1 |
born to be turbocharged
24
Rep 1,347
Hi guys,
a few days ago Jeff mentioned s/t about plasma coils ignition boosters getting prepared to go public. Well, I asked him what's that about - and received no answer. Thx Jeff. Anyway, I did UTFG and found some really brief info on it, mostly marketing only one dyno... ehm, not chart, I had to do the chart by myself, so a dyno table, showing s/t like 12hp/12ftlb increase on a V8 supercharged mustang + mentioned sideways that on similar N/A car it was 4HP/0TQ... right after that I found some japanese company selling 3 variations of I am not really sure what are they about - some plasma booster, plasma direct and plasma spark or what. They have an application list available on their website, of course when I compared BMW prices with let's say a subbie, it was double (we are getting used to that, don't we?), the first two products were for 1200$... So, guys, I am just curious, if U have some experiences - direct or indirect - with the plasma coils, or opinions, pls, share. Some links: older article, containing an interview with the inventor http://www.autofieldguide.com/articles/100202.html recent manufacturer http://www.okadaprojects.com/usa/products.htm |
07-16-2007, 03:35 PM | #2 |
Rep 78
Interesting article. I have no direct experience with this technology. It seems like this would have a much greater effect on a conventionally injected engine rather than a direct injected one. My reasoning being that since the fuel air mixture is much more uniformly distributed in the cylinder in a conventional setup, increases in delivered spark energy result in a faster burn. The net effect would be the same as allowing one to advance the timing a few degrees.
For direct injection, in many cases the fuel is not evenly distributed in the cylinder at the start of ignition and the fuel can be sprayed very late in the compression cycle. Given that I am not sure what effect simply increasing the delivered spark energy would have. Then again, this is just a guess on my part and should not be construed as fact. |
07-16-2007, 03:57 PM | #3 |
Rep 455
I ran them on my e36 M3,my only problem is they said that the car would have no isssues with them,after a while people found out that they threw the whole ingnition feedback system into a haze and made the car not have adaptation.
I thought they went out of buisnes,I want to throw an email at them for making my car run lean and almost blowing a headgasket. edit the company I had were ignition solutions,I don't know if these are the same guys. |
07-16-2007, 04:14 PM | #5 |
24
Rep 1,347
imo the idea is great, but it would need some deeper integration with the ECU to take full advantage of it. Imagine an engine like the N54, @ 6000 rpm, with it's cylinder full of fresh HP cooled air, getting a nice squirt of gas inside @ the right moment, than getting a nice series of lets say 10-15 sparks in an eyewink, burning everything it has within the most effective part of the piston's path... almost erotic
07-17-2007, 08:55 PM | #6 |
316
Rep 1,517
Drives: Ever changing fleet
I didn't want to get all tangled up in this guys, but these "plasma coils" have been around in one variation or another for years now. Basically they take the stock coil, add an LED, monkey around with the circuit a bit and then sell it to you for an arm and a leg. They tend to fail, they tend to make no power, and they tend to cause strange issues. If you aren't having any misfiring problems, they don't do anything. Increased fuel economy is placebo, the power gains are minimal at best. Please research this one carefully, its about as bad as the "turbonator" and you'll see lots of glowing reviews on that little piece of history. The power of persuasion is very real.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
07-17-2007, 09:16 PM | #7 | |
Rep 3,888
07-17-2007, 11:25 PM | #8 |
316
Rep 1,517
I agree with you Zen, however an MSD on a Rotary engine, which is difficult to ignite the mixture across the entire rotor anyway (reason for leading and trailing spark plugs) with a distro is quite a different application. MSD boxes do tend to make a difference, but mostly when the stock system is maxxed.
Anyway, I've said my piece.
07-17-2007, 11:39 PM | #9 | |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
If you're not misfiring, an "upgraded" ignition system will do nothing for you. I also had a 3rd gen RX7 that benefited from an HKS twin spark. But that was because the factory ignition system simply couldn't get the spark to bridge the gap above 6500rpm at full boost. It would audible misfire and fall flat on its face. This is not the case with the 335i so I'm not sure what the advantage of any type of ignition mod would have. shiv |
07-18-2007, 04:13 AM | #10 |
24
Rep 1,347
Well, thank U guys for your valuable inputs. Now I'm really curious, what miracle is going to be shown by eurobahn. I wonder if Jeff just missed this thread, or he wants to keep his stuff secret, ot he is ignoring it completely
07-18-2007, 07:17 AM | #11 | ||
Rep 3,888
07-19-2007, 01:38 PM | #12 |
Rep 173
If it was really that good they would have designed it into the M3...
Was this not on one of the Myth Busters as well. I saw this tested with all those other power improvement/fuel saver stuff.
Jun 2006 330i Manual, Active Cruise, Comfort Access, Nav prof, Voice, Bluetooth
08-27-2007, 03:10 PM | #13 |
Rep 30
Found this on http://www.eurobahn.us/plasmadirectcoils.html
I tried researching it here and ran into this thread... I thought you might be interested in taking a look. |
