6 injectors replaced! Why did they fail?
10-02-2012, 02:59 PM | #1 |
Rep 2,554
My car was misfiring in cylinders 5 and 6 and so the dealership decided to replace all the injectors under CPO warranty.
My question is, why are the fuel injectors failing? Aren't they supposed to last the life time of the car? (and why does it seem like cylinders 5 and 6 are always the most problematic? ) |
10-02-2012, 03:18 PM | #2 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Just because they replaced them doesn't mean they were failing. I think you would have known if they were all bad. They likely replaced them because they fell under the recall notice.
The i8 needs a V8 amirite?
10-02-2012, 03:31 PM | #3 | |
Rep 2,554
Does it have to do with carbon build up on the injectors that cause them to spray unevenly? |
10-02-2012, 03:31 PM | #4 |
Rep 3,262
First check if the misfires disappeared...
10-02-2012, 03:43 PM | #6 |
Rep 2,554
10-02-2012, 04:07 PM | #7 |
76
Rep 1,883
I'd imagine they have a very low tolerance for error, which can be somewhat supported by the fact they need to be coded which I believe is to accomodate minor manufacturing inconsistencies.
If it makes you feel better, I have only 60k miles and cyl 1 is on its 4th inj, cyl 2,4,5,6 are on their 3rd injector and cyl 3 is on its 5th injector.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
10-02-2012, 04:08 PM | #8 | |
Rep 2,554
10-02-2012, 04:16 PM | #9 |
76
Rep 1,883
only the 1st replacement set was under warranty. I ponied up the rest for the following 9. Had my warranty voided. Twice.
10-02-2012, 04:18 PM | #10 | |
76
Rep 1,883
Car has cost me a lot of money, but I drive it harder than most.
10-02-2012, 04:23 PM | #11 |
Rep 4,393
I just bought one injector to fix my misfires in cylinder 3. I wanted to do all 6 but don't have the money to do that right now. I should also probably get a carbon cleaning soon since i'm at 51k miles...
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ |
10-02-2012, 04:27 PM | #12 |
Rep 2,554
I think the rare misfires could have been caused by my spark plugs... 47k miles and i haven't changed them yet
10-02-2012, 04:28 PM | #13 | |
Rep 495
My car has 60k miles, and had an issue with injector once and they replaced only the faulty injector under CPO. I love my car and it is tune with FBO and I drive it hard when i want but not everyday. Its been pretty reliable thus far, but you are freaking me out...
GIAC stage II|AA DP|AA Charge pipe and BOV|AFE S2 Intake|HELIX FMIC
10-02-2012, 04:31 PM | #14 | |
76
Rep 1,883
1. If you lug your engine in 3rd and the misfires happen right away, it was usually a bad coil. 2. If you lug your engine in 3rd and the misfires happen after being in WOT for a little bit after full boost, then it was usually a bad injector (majority of the causes for my misfires). 3. If the car only misfires at really high rpm when going WOT, then it was the spark plugs. (rarely ever was the case).
10-02-2012, 04:34 PM | #15 | |
76
Rep 1,883
Overall, I haven't had any major issues. Never had a lpfp or hpfp go out on me in 60k miles (replaced both becuase I wanted to). I did break my drive shaft, but I drag race my car A LOT. Well over 300 1/4 mile passes.
10-02-2012, 04:37 PM | #16 | |
Rep 4,393
10-02-2012, 04:45 PM | #17 | |
Rep 495
I think I will go bigger turbos before I go Meth, I also use the fuel injector cleaner every 6 months, I know many say it does nothing but I feel a difference every time I use it.
10-03-2012, 02:46 PM | #18 | ||||
Rep 1,035
Your cyl #1 issue may also be a carbon buildup issue on the intake valves. This can cause misfires and misdiagnosed as an injector problem at times. Did you have the injector recall done? If so do you know how many injectors they replaced? ( you do not automatically get 6 new ones FYI) Also if you need a carbon cleaning done shoot me a PM I can help you out. |
10-03-2012, 04:31 PM | #19 |
Rep 2,554
10-03-2012, 04:52 PM | #20 |
Rep 2,621
Haven't the problems been more electrical? Ie the piezo crystals fail?
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
10-03-2012, 05:55 PM | #21 | |
Rep 6,136
10-03-2012, 06:54 PM | #22 |
Rep 4,393
Hahaha I wish I did... It was hard enough finding a manual 335 that was AWD though so adding a CPO to that would have made it near impossible. I had been looking for months and got fed up and just took the risk... Kinda regret it now
