Need Help In Nc
10-26-2012, 08:56 AM | #1 |
Chump
131
Rep 289
Drives: '16 LBB M2/'18 X3 M40i/'16 X5d
Need Help In Nc
I am having some issues with my car.2007 335i. Misfires on 4-6, O2 sensors reading lean. Started with just changing the sparkplugs to no avail. I would like to see if anyone has a BMW diagnostic scanner or something that is more in depth than just a normal code reader. Or if you know someone who has had similar problems, please advise!
10-26-2012, 01:55 PM | #2 |
Rep 487
Are you tuned? If so, which one?
10-26-2012, 04:32 PM | #4 |
Rep 487
I had similiar symptoms and did everything I could possibly think of to fix it - replaced all 4 o2 sensors, replaced spark plugs, even got a walnut blast. It wasn't until I removed my JB3 (to send it off for the upgrade) that I stopped getting these codes/misfires. I haven't seen a code or had a misfire (except for once recently, got a 1/2 engine light but the code was for something like a low fuel blah,blah,blah...sorta weird) since I put in the JB4. I'm thinking maybe the +3 wasn't compatible w/the ecu software upgrade I received when I had my injectors replaced (which I was hoping would fix the misfires, but it didn't). Call it coincidence or just in need of an upgrade, but I'd do the upgrade and see if that works.
10-27-2012, 12:43 PM | #5 |
Chump
131
Rep 289
Did it all go away when you pulled the JB3? If I can get the car running without the JB3 installed, that would be nice while I am waiting for the upgrade.
10-27-2012, 07:39 PM | #6 |
Rep 487
I haven't had any problems since I upgraded. I didn't have any problems while the tune was out, car drove fine, minus the cat/o2 codes I got which I was expecting. None of the other codes came back after removing the tune and after installing the upgrade. The car will drive noticeably slower compared to when it's installed. Nothing unusual.
