Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > DCT Paddle Install Help!!!
      10-27-2012, 03:57 AM   #1
eriktufa
3r1k
eriktufa's Avatar
Australia
30
Drives: 2008 MY08 BMW E92 335i
Guys,
Trying to retrofit M3 DCT Paddle Shift however I can't remove the old paddle shift pin from the multi function button.
I don't want to strip or destroy it by force.
Can you help? everything is already out except the pin.
I'm unsure if I should disassemble the multi function button.
Thanks
      10-27-2012, 05:39 AM   #2
_ink
Jedi samurai ninja turtle
_ink's Avatar
Australia
619
Drives: X3 M40i 2018
2018 X3 M40i  [0.00]
You can't retrofit the m3 paddles without the whole module that the paddles are attached to. Is that what you are referring to?
      10-27-2012, 05:45 AM   #3
Delusive
Delusive's Avatar
Drives: Bagged E92
Pull slightly towards you from where it connects then pull it sideways because there's a little clip inside thats attached, it doesn't take much force. I did it the first time easily and yes you can retrofit them, it's been done many times by others so don't listen to others saying you can't.
      10-27-2012, 05:49 AM   #4
eriktufa
3r1k
eriktufa's Avatar
Australia
30
Spent 4 hours as a newbie to remove everything safely and that pin made me put everything back to stock again just because I need to drive the car!!
Madness.
Thanks JS-NA.E92. I'll give it a try tomorrow.
When you said pull towards me, just straight towards me? no sideways action?
I wiggled that thing so many times then gave up.
      10-27-2012, 06:19 AM   #5
sbce90
Me Boosta
sbce90's Avatar
Australia
249
Drives: 320i / MB C63 / VW up!
The retrofit can be done as has been said - it is a case of wiggling it I guess. I had the paddle retrofit on my car and I got a bit excited and connected the paddle to the clip before putting it through the wheel. I couldn't get it out hahah! Same situation you're in. I gave up and gave it to a friend who got it out no problems.
      10-27-2012, 12:13 PM   #6
Delusive
Delusive's Avatar
Drives: Bagged E92
See in the picture how your holding it? hold it like that and pull towards you slightly so it unclips then you wiggle/pull it sideways while your doing that first action. First time I did it only took me 5 minutes to figure out there was something clipped inside the multi-function button holding it in place.
