BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Car wont start sometimes. HELP!
      11-05-2012, 11:09 PM   #1
Lolitskasey
Lolitskasey's Avatar
11
Drives: 2006 Black 325xi
So this pass week my car some times wont start, i put the key in and try to start it and it just clicks and doesn't even turn over. I put a volt meter to my batt and its floating at the normal 12 volts. Anyone have this same problem or fix? The car is a 2006 325XI
Thanks,
Kasey
      11-06-2012, 12:23 AM   #2
Casca
Drives: E90 6MT
Can still be your battery. Not enough amperage to start the car probably. Remove it and have a parts store check it for you.
      11-07-2012, 04:00 PM   #3
Lolitskasey
11
That's seems kinda odd though, cause some days it works perfect and some days it doesn't, don't you think if it was my batt it wouldn't start more often then it would start. Cause the last time it happened I drove 90 miles shut my car off for about 10 minuets and it didn't start. Got it to start then drove about 5 miles shut it down for the night and it has been working fine since then. Maybe it could still be my batt. I guess I will take it in and see what they can find.
      11-07-2012, 06:58 PM   #4
nate5ks
Drives: 2006 BMW 330xi
Could be the alternator also. A good batt should hover between 12.5 and 13.5 volts, 12 is on the low side. When the alternator is going bad, charging will be intermittent. Sometimes it will charge the battery and other times the car will start shutting itself off while you're driving. Trust me I know.
      11-08-2012, 05:07 PM   #5
Lolitskasey
11
The volt meter read 12.7-8. So I guess I will test my alt today after work and see if that is the problem.
      11-09-2012, 02:54 PM   #6
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
Another issue could be an intermittent fault in the IBS.
Tom
      11-10-2012, 08:38 PM   #7
queensfield
Drives: 2006 330i E90
If your battery hasn't been changed since 2006, that could be the culprit. While IBS is a possibility, it could be the starter itself, which is known to go bad and is a pain in the neck to replace since it is buried down deep.
