Oil Change Question...
08-09-2007, 12:54 PM | #1 |
Modaholic
88
Rep 1,705
I'm going to do an oil change tonight... just hit 5,000 miles, so it's about time. This is my first time doing an oil change, so I was wondering if the oil needs to be at a certain temperature to drain better?
Euro Delivery - April 2007
08-09-2007, 01:08 PM | #2 |
Rep 6,664
All I know is if you've just run the engine for a while, the oil is too damned hot. Everything is too hot to work with for that matter. Lately I've been changing oil on a weekend morning after the car has cooled off all night. Driving the car onto the ramps is enough to get the oil a little warm and make sure it all flows out. Everything is much easier to work on (oil filter, oil filter cap, etc) when its not scalding hot..
Just my $0.02, as for a specific temperature, I wouldn't imagine there really is. When you go to the dealership they change it after you drove it there, so I imagine its pretty hot at the dealership. The oil capacity is 6.5. After letting it drain for a long time, I will take the 1/2 qt I had leftover from the previous oil change and dump it through, get rid of the crap in the oil filter basin (you'll know what I mean when you take off the oil filter), etc.. Let that drain.. Then I'll put the bolt back on and fill her up..
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
08-09-2007, 02:52 PM | #3 |
Rep 1,187
I am in the same camp as Josh49. After years of burning my fingers I now do mine cold.
I doubt that there is any difference between changing 95% of the oil and 99% of the oil. These are made up numbers, but the point is that even cold you get almost all of the oil changed. Cold does not burn the fingers and, more importantly, leaves a thicker oil film on the parts (I run the car briefly to get it up on ramps). This should provide, I think/hope/rationalize better protection while the oil pressure builds on the first start after the change. But in truth I doubt that it matters enough to make a measurable difference over the life of the car. |
08-09-2007, 03:01 PM | #4 |
Modaholic
88
Rep 1,705
Cool - that's what I was hoping for. I was really concerned about changing the oil when it's at its full operating temp.
08-09-2007, 03:45 PM | #5 |
Rep 1,353
Did my first oil change about 3 weeks ago, after 5120 miles. No specific temp is needed. I just ran my car for about 3 mins and waited for 15 mins after unplugging the drain bolt. Then started my engine again for about 30 sec, at which time more oil was drained. Waited for another 5 min, then I plugged back the bolt. After that it was a breeze! Very simple process.
Bottom line: it is best to warm up the oil a bit rather than do it cold. Just my dot oh two. By the way, I opened the filter cap with my hand, using a rubber glove, and that provided me a good grip on the cap. I also replaced the cap back on, again using hand. Advice: make sure you line up the green dots/marks. Cheers!
Enjoy the ride!
08-09-2007, 03:53 PM | #6 |
19
Rep 349
i already have 18000 kms onn mine and there still no oil change warning sign., will this be dangerous?
black saph./black leather/xenon/heated seatscomfort pkg./advantage pkg |
08-09-2007, 06:40 PM | #7 |
Modaholic
88
Rep 1,705
You should be coming up on the mandatory oil change if you're just going by the factory oil change intervals... I believe the indicator will light up at 12k-15k miles, from what I've seen. I just choose to do an oil change earlier on, for peace of mind.
08-09-2007, 06:58 PM | #8 |
Rep 6,664
How'd it go?
08-09-2007, 07:53 PM | #9 |
Modaholic
88
Rep 1,705
Great! I poured all 7 quarts in, and it still didn't register at the MAX level - a little surprising, but I'm not worried. My oil pan's cap didn't really close right, so some of the oil spilled onto the ground. Next time, I'll have to monitor that a little more closely. Drove the car a little, and everything felt smoother. The oil that drained was pretty dark... I couldn't imagine waiting another 7k miles for an oil change!
A special thanks to all the forum members who posted their DIYs! Without you guys, I would never have had the courage to go through with this!
