M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      12-15-2012, 12:55 PM   #1
avi8tir
avi8tir's Avatar
397
Drives: ///M
Excessive Camber with H&R Springs
sorry, dont have a pic, but will post one.
Got my car back from getting H&R installed. Height is great but the camber is WAY excessive in my opinion - especially the front.
Can someone else with H&R take a picture from the front of the car showing the camber? I'll be putting 21's on soon and I really done want the lowered Civic look.
thanks !
      12-15-2012, 01:10 PM   #2
mindlessmark07
mindlessmark07's Avatar
47
Drives: 2013 F10 M5
thanks !
Thanks for letting us know! I have my appointment for installation this coming Friday @ EAS. I will post pics as soon as it's done. I will also find out what we can do to resolve a camber problem if its to much.
MindlessMark07
///2013 M5 Alpine White/Black,Orange County CA\\\
      12-15-2012, 03:36 PM   #3
mwlmd
mwlmd's Avatar
Drives: Porsche 991 TTS
thanks !
Are you getting an alignment done?
CURRENT:
His: Porsche 991 Turbo S
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      12-15-2012, 05:08 PM   #4
star21
star21's Avatar
Drives: F10 M5 en route
+1. You should always get your alignment checked out when lowering the car. Preferably go to a shop that understands and has worked on performance cars instead of those national chain stores that get people in and out in a flash. Equally important besides checking the camber is making sure the toe is correct (an excessive amount will result in scrubbing tire life a lot faster).
      12-15-2012, 05:19 PM   #5
Pazzo009
Pazzo009's Avatar
1110
Drives: X5M,M3(46&36),812SF
I always thought it was a rule of thumb to get an alignment after lowering. I was curious about lowering mine with H&R's...but ride quality is important and due to "only so much" you can adjust camber after lowering it persuaded me not to. Not only do I dislike compromised ride quality, but I hate front tire noise from poor camber.
      12-15-2012, 05:49 PM   #6
avi8tir
avi8tir's Avatar
397
Drives: ///M
Yes, alignment was done, but they didnt give me a print out!
this could just be a result of the lowering but I didnt have this issue on my E60 M5.
      12-15-2012, 05:50 PM   #7
avi8tir
avi8tir's Avatar
397
Drives: ///M
I was a skeptic too.... especially since I have never used H&R before. But, I'll honestly say that there is basically ZERO difference in ride quality.
      12-15-2012, 06:02 PM   #8
mwlmd
mwlmd's Avatar
I was a skeptic too.... especially since I have never used H&R before. But, I'll honestly day that there is basically ZERO difference in ride quality.
What did you pay total for H&R springs, install and alignment?
CURRENT:
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      12-15-2012, 07:48 PM   #9
star21
star21's Avatar
Have you taken it to this alignment shop regularly? Do they typically not provide one? If they regularly do provide one and missed it this time maybe you can go back and try to ask for one.
Manufacturer cars have a leeway on alignment adjustment with tolerance range so unless you're lowering the vehicle considerably (i.e. slammed on coilovers) the car's OEM components should be able to compensate for the subtle lowered height of the H&R springs.
If the camber concerns you to the point of worry, take it back and have them readjust to your liking. I'm sure they can set it to your liking that's still within tolerance.
      12-15-2012, 08:07 PM   #10
mindlessmark07
47
Drives: 2013 F10 M5
Also, does changing springs void your warranty? I know that technically as long as any issues that require repair would be covered as long as the modification didn't cause it, but in the real world, would the dealership just see the springs and cancel the warranty?
MindlessMark07
      12-15-2012, 08:53 PM   #11
BarryB
BarryB's Avatar
Drives: 30Jahre M5 plus a few more M's
No excessive camber effect at all. I was told to wait 2 weeks for the alignment. Getting spacers then alignment on wed.
I have side view pics in another thread so can't see camber. Looks close to stock camber to me?
Current non-BMW's
20 Jeep Grand Cherokee
03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)
15 Turbo S (Kobb tune and Kline exhaust)
      12-15-2012, 09:14 PM   #12
Grayblack
Grayblack's Avatar
182
Drives: E92 M3 and G07 X7
The dealer will likely deny any suspension claims because of the aftermarket springs. This happened to me on my old M3.
Can someone post pics of the front and rear cambers with h&r springs?
      12-17-2012, 10:44 AM   #13
Vic55
Vic55's Avatar
19355
Drives: 2023 BMW M8 Competition Coupe
I did my alignment 2 days after the H&R install.... no visual camber concerns prior or after. The drop is minor guys, 1 inch in the front and 6/10ths in the rear... it should not create much of an issue. And the alignment will rectify.
And in reality a little negative camber is fine for those who drive the corners alot. To avoid real tire wear the toe is the measurement that needs to be spot on.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      12-17-2012, 10:53 AM   #14
mindlessmark07
47
Drives: 2013 F10 M5
Originally Posted by Vic55
I did my alignment 2 days after the H&R install.... no visually camber concerns prior or after.
Thanks for the tips!
MindlessMark07
      12-17-2012, 11:03 AM   #15
Vic55
Vic55's Avatar
19355
Mark you can get an alignment done for 100 bucks at WheelWarehouse down the road from EAS. They did mine and I find no travel at lower or higher speeds and the car is as planted as ever at 160 mph and 16 mph LOL
      12-17-2012, 11:14 AM   #16
mindlessmark07
47
Drives: 2013 F10 M5
Thanks for the recommendation. I really appreciate the help.
MindlessMark07
      12-24-2012, 12:43 PM   #17
BarryB
BarryB's Avatar
My alignment was barely out after the springs :-)
Happy as ever
Current non-BMW's
      12-24-2012, 01:01 PM   #18
mindlessmark07
47
Drives: 2013 F10 M5
I had EAS do an alignment while the car was with them. The alignment plus the spacers make it look that the car was delivered from the factory that way. Just do it. Don't fear the drop.
MindlessMark07
      12-24-2012, 01:14 PM   #19
BarryB
BarryB's Avatar
Exactly, (and with larger exhaust tips)
Current non-BMW's
      12-25-2012, 10:29 PM   #20
cpiguy
cpiguy's Avatar
Drives: 2014 Porsche 911 Turbo S
No camber issues either.
CPIGUY
2017 Ferrari 488 Spider
2019 Tesla Model 3 Performance
2019 BMW X5 MSport, in coming
      07-18-2013, 06:42 PM   #21
nugent
nugent's Avatar
Drives: f10 m5
any ideas what the specs on camber and toe should be?
thanks.
e92 m3 6MT, RS4 6MT, S4 Avant 6MT, WRX 5MT, Corsica
      07-19-2013, 09:56 AM   #22
Vic55
Vic55's Avatar
19355
thanks.
I would need to check my latest alignment sheet. I cant "supposedly" get my car aligned at the dealer because I have aftermarket wheels and their rack needs the factory wheels with those holes around the hubs I guess.
I use a local shop that is well known and I think they paid for the 2013 chassis info... I know I have the M6 numbers.
m5post
