Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Factory Fitted Sound?
      05-23-2005, 03:42 PM   #1
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
Does anyone have any comments on the standard sound? I am not going to add logic 7 or anything. The sound on an E46 wasn't good at all, and so I took my car up the road to get Hertz sub and amp installed. Am I going to need this on my new car?
Anyone got pictures of retrofitted sound systems?
I was thinking maybe it could fit into that storage space in the boot(aka trunk) where the spare would've gone?
      05-23-2005, 03:50 PM   #2
itsmerd
Drives: BMW 320D E90 and E92
I actually have the same question. The only "sound" option I took is the radio professional but I am planning to built in my own choice of speakers in the original spaces. Anyone experience with this if cabels etc. are sufficient there and if all if 'communicating' with each other as BMW uses high CAN bus wirings so I'm not sure if all will fit that easily. I have been told that it won't be possible to built in a CD changer yourself... Who has experience or information?
Driving a BMW K1200GT and as of August 1, the 320d (E90) as well...
      05-24-2005, 03:04 AM   #3
ldpantoja
Puerto Rico
15
Drives: 330i (E90)
Go to www.bavsounds.com
Give them a few months and they should come out with some custom kits
      05-26-2005, 09:30 AM   #4
itsmerd
Thanks Idpantoja!
I didn't know this site and company but it seems to be the one I need! Hope they will be able to deliver to Europe..
      05-26-2005, 09:56 AM   #5
abdulh
abdulh's Avatar
Drives: E90 320iSE
i cant say i am a music expert but the sound system seems very good (have the professional version), its more or less on par with the jag and quite a bit better then the e46, not that i have played it load, perhaps i will try tonight.
      05-26-2005, 11:32 AM   #6
kelvinso
kelvinso's Avatar
22
Drives: BMW 320i E90 TiAg/Lemon
Hi abdulh,
Did you get the 10 speaker hi-fi loudspeaker package on your new 320i? Or the standard 6 speakers with CD professional (w/o i-drive)? Can you tell me where are all those six standard speakers exactly? Have you got any speakers behind the rear seats?? The 320i is not in HK yet and I am wondering if I need to add the 10 speaker option if I place an order on 320i. Thanks for your advice in advance.
      05-26-2005, 11:47 AM   #7
jiggax23
Drives: e90
only way I would add a system to this car is if you're going to change every stereo component out. I would not add a system that consisted of just an amp and subs to the stock radio. Or simply change out the speakers and use the stock radio. The logic 7 is actually pretty good, not on par with some of the high end systems out there, but definitely better than just about any other stock system out there. Unless u were planning to add an aftermarket head unit, amps, AND speakers, i'd just add the logic 7. If it's pleasing to my ears after switching over from Focal Polykevlars, it should be pleasant to just about any other set of ears (unless you are a true hardcore audiophile).
      05-26-2005, 04:17 PM   #8
abdulh
abdulh's Avatar
Drives: E90 320iSE
Originally Posted by kelvinso
Hi abdulh,
mate i only have the 6 speakers
      05-26-2005, 04:42 PM   #9
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
Hi abdulh,
With the six-speaker standard setup you get:
a full-range 4 inch speaker in the front door
a 6.5 inch woofer with enclosure under the seat
a full-range 4 inch speaker in the rear parcel shelf
And btw, it sounds really bad.
      05-26-2005, 08:23 PM   #10
kelvinso
kelvinso's Avatar
22
Guys, thanks for all info.
Then anyone got experience with the 10 speakers setup??
      05-27-2005, 03:31 AM   #11
abdulh
abdulh's Avatar
Drives: E90 320iSE
so thats where the other speakers are, i saw the ones in the door and on the parcel shelf but couldnt find any more.
as i said i am quite pleased with the sound system in mine, but then i am not much of a music fanatic.
      05-27-2005, 04:10 AM   #12
Broken1
Addict
Broken1's Avatar
203
Well then, I'd better start saving some money for my sound! I know a guy up the road from me....I wonder if he can fit the amp and stuff into that space in the boot? It'll be interesting to see...i'll show you all when i get my car and get it done!
      05-27-2005, 04:17 AM   #13
RedStripe
RedStripe's Avatar
Drives: 2006 BMW 325i
2006 BMW 325i  [0.00]
Does this help you out? This is the Logic 7 setup. The 10 speaker layout is basically the same, except you don't have a center speaker and I guess the two tweeters in the rear passenger doors.
      05-27-2005, 04:55 AM   #14
Broken1
Addict
Broken1's Avatar
203
Which website did you get that from????
      05-28-2005, 10:49 AM   #15
Broken1
Addict
Broken1's Avatar
203
BUMP!!
I want to know where that picture came from..WHAT WEBSITE!!!
      05-28-2005, 12:28 PM   #16
Gareth SA
Drives: Demonstrator E90's
Std sound reply
The standard sound system is a lot better than the one on the E46
But... when you adjust the bass to three quarters and play music at high volume , there is distortion where with the HI FI loudspeaker the clarity would be perfect.
The Hi Fi loudspeaker system is recommended (incredible bass and clarity at all volume levels).
I did not find a huge difference between Hi fi loudspeaker and DSP (apart from being able to save your sound channel settings)
      05-28-2005, 12:31 PM   #17
Agni
Agni's Avatar
Drives: F36 435i M Gran Coupe
2009 335xi  [0.00]
2006 325i  [0.00]
www.bmwusa.com/new3
      05-28-2005, 04:18 PM   #18
segfault
Drives: No longer own a BMW
Link should be:
http://www.bavsound.com/
      01-29-2006, 11:41 AM   #19
MAK
Drives: E90 316i
I have the Standard System Can I upgrade to the HiFi?
