M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      02-07-2013, 04:31 PM   #1
Fly M5
Drives: 2014 M6GC CP & 2015 M3
Dyno'd (stock air box/block off plates/charcoal filter delete)
Went to get another dyno after dealer installed plates..sure enough i was right and the call feels great now!
My mods are RPI GTS exhaust and RPI air scoops which were on all the runs.
run#8 is with stock air box on 1/31 temp: 77 degrees
run#16 is with block off plates on 2/6 temp: 65 degrees
run #19 is with Charcoal filter delete
Current: 2014 M6GC CP and 2015 M3
Past: 2013 M5, 2012 E63, 2011 panamera turbo, 2010 E63, 2010 GTR, 2009 C63, 2008 M5
      02-07-2013, 04:33 PM   #2
Fly M5
We had to do few extra runs before we got started yesterday as i couldn't get the
car off the MDM mode.
      02-07-2013, 04:48 PM   #3
stealth.pilot
Knight Commander
stealth.pilot's Avatar
United Kingdom
559
Drives: 2014 911 Turbo S
Wow. I need the new air box and the charcoal filter delete.
Bradone1 any chance your service advisor at South BMW can help us out?
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      02-07-2013, 05:03 PM   #4
Mperial
Mperial's Avatar
Drives: 2016 M3, 2017 X1
+1
Very impressive numbers...
      02-07-2013, 05:21 PM   #5
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Would you mind posting the dyno results under the DYI or Exhaust thread on the charcoal filter delete?
Current: '16 GT4
Past ///Ms:
'13 F10 M5, Alpine Weiss III/Sakhir Orange Full
'10 E60 M5, Space Gray/Black
      02-07-2013, 05:29 PM   #6
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
I can't see the pictures from my work computer. How much horsepower change was there from the Charcoal Filter delete? Can someone post this for me. Thanks!
      02-07-2013, 05:32 PM   #7
Mperial
Mperial's Avatar
run#8 is with stock air box on 1/31 temp: 77 degrees - HP: 496.61 TQ: 468.59
run#16 is with block off plates on 2/6 temp: 65 degrees HP: 536.00 TQ: 517.03
run #19 is with Charcoal filter delete HP: 551.47 TQ: 532.39
      02-07-2013, 05:38 PM   #8
Vic55
Vic55's Avatar
19353
Drives: 2023 BMW M8 Competition Coupe
pardon the ignorance, whats with the plates thing???
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      02-07-2013, 05:48 PM   #9
Warehouser
Warehouser's Avatar
29
Drives: 22 X5M TBlue2
Some of the airboxes were coming off the production line with holes in the bottom of them. Then they started to add silver plates to cover the holes. Seems like most of the later built cars had the plates, mine does.
      02-07-2013, 05:50 PM   #10
Vic55
Vic55's Avatar
19353
Oh ok thanks---- mine is Sept build--- I think Im ok- But Ill check.
      02-07-2013, 05:59 PM   #11
BarryB
BarryB's Avatar
Drives: 30Jahre M5 plus a few more M's
So if I'm understanding this correctly about 625 crank hp? Seems high for stock ecu with exhaust, scoops and plates? But very impressive. Were these #'s "corrected" on the graph?
Current non-BMW's
20 Jeep Grand Cherokee
03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)
15 Turbo S (Kobb tune and Kline exhaust)
      02-07-2013, 06:07 PM   #12
Vic55
Vic55's Avatar
19353
According to the top right it looks uncorrected (non SAE)....
      02-07-2013, 06:08 PM   #13
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Since my airbox has a snorkel instead of a hole or a block off plate, and the build date was the end of November 2012, I wonder what BMW had in mind as the final design of the airbox? Has anyone with a later build date taken their airbox apart? Why would BMW leave the hole initially and then block it off completely, only to add the snorkel later?
      02-07-2013, 07:03 PM   #14
Warehouser
Warehouser's Avatar
29
Late Oct build here, and have plates.
      02-07-2013, 07:20 PM   #15
Rob///M5
Rob///M5's Avatar
76
Drives: 2013 M5 SSII
2013 BMW M5  [10.00]
15hp for filter delete?
That's crazy
      02-07-2013, 07:35 PM   #16
Vic55
Vic55's Avatar
19353
That's crazy
Heard.
I removed mine and I did feel the car was stronger... he ran his car 3 runs after the block plate was added so maybe the car was still adapting and the filters showed gains they didnt deserve?
      02-07-2013, 08:04 PM   #17
mainly
41
Drives: 991 GT3, '12 CLS63 Kleemann K3
sorry this is very hard to believe.
      02-07-2013, 08:20 PM   #18
ColdList
ColdList's Avatar
154
Drives: McLaren 675LT / C7 Z07
I don't find it so hard. Actually, the numbers he is posting after installing the plates reflect ACTUAL numbers recorded on stock F10s by many people. Seems to be becoming pretty common knowledge that BMW grossly understated the HP and Torque on the stock cars. Likely that the hole in his box "took away" and the plates simply restored the power.
Also, the charcoal deletes do seem to work. I did mine and it feels a bit more "loosened up" the same way it did on my E60. I don't know about necessarily 15 hp but it is enough to be noticed.
      02-07-2013, 08:42 PM   #19
Rotorocious
Rotorocious's Avatar
103
Drives: 335xi
I'm also skeptical.
Same time between runs? Same fans etc?
I can Make similar gains by doing some hot heat soaked runs then doing a cold run.
Not to question your credibility but just curious on the other variables.
I've even dyno'd it without any exhaust on to see if these overpriced exhausts had any real gains.
      02-07-2013, 09:43 PM   #20
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
That's crazy
I know! This might prove my hypothesis correct.
I removed my charcoal filters tonight and also found out that I have the block off plates. My car is an August 2012 build.
Here's some low quality iPhone pix for your viewing pleasure.
After I removed the stupid environmentalist filters, I went for a test drive and raced a riced out civic or two. The results of my drive were excellent. The butt dyno was detecting appreciable gains and I felt like I could hear the turbos a little better. Prolly all in my head though or this case in my butt. Lol!
      02-07-2013, 09:54 PM   #21
MasterDank
Boats & Hoes
MasterDank's Avatar
Drives: 13 F10 M5 Sakhir Orang,Chohiba
...... Without a video of each run with temps, IAT,EGT, Ambient and humidity. Those are really far fetched numbers for the changes made... Tuning and full exhaust are bringing the same kind of numbers as the block off plate. 40 HP from a block off plate that should do lil to no difference on a dyno, with a fan blowing in to the RPI air ducts.. Unless the first run or runs were with no fans or some other change. How can removing a thin layer of filter bring an amazing 15 HP and completely removing the filter or putting on the gruppe M intake only yield the same results. Your first change (Plates) restricts the amount of flow to the filter and the second Removing the C filter helps flow more air.... How do they compound to make more power rather then cancel each other out?...
Sorry to be a skeptic but seems unusual to yield such large results on stock software and to gain TQ and HP both times from opposite changes, seems to good to be true.
Aloha
Alex
Change is inevitable Progress Is optional
      02-07-2013, 10:11 PM   #22
MasterDank
Boats & Hoes
MasterDank's Avatar
This is kind of my point with out the extra filter you hear a difference.. If you take off the plates you will hear similar sound... So how can adding more air and restricting the air not negate each other? Especially on a none heat soaked car on a dyno with proper air flow.... 50+ HP and 70+ TQ from two small mods on a stock intake.....??? SAY WHAT???? No tune no exhaust change... how could an air pump be so poorly designed from factory?
Aloha
Alex
m5post
