The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > N55 135 to N54 335
      02-09-2013, 03:31 AM   #1
recce
recce's Avatar
Australia
23
Drives: 135i & 335i
N55 135 to N54 335
Hi All, I am from the 1 series forum and would like to seek some advise on the 3 series forum.
I am thinking of doing a swap from my current N55 135 to a N54 335 sedan. I need a 5 seater car for the family and the 335 sedan seems a good choice. Looking at 08 or 09 335 and was wondering if there is something I should be aware of (beside the fuel pump problem). Thanks!
2009 E90 335i / JB4 G5 ISO / M3 front sway bar / AFE DCI / Air Scoop / BC-BR Coilover /
      02-09-2013, 03:45 AM   #2
Red_Bean_Bun
62
Drives: E92
5 seater 335 ? Would still be sqeezy in the rear ......
      02-09-2013, 04:48 AM   #3
Jin-ActiveMotorwerke
Drives: BMW E46 330i
Fuel pump isn't that expensive to replace anyway.
You still get a lot more room than your 135i.
Oil leak from the engine, you can see from the front around the oil filter housing. Probably almost every 335i will eventually leak through there, not that expensive to fix either if you know where to go. Also transmission mechatronics plug seal can leak, but it's a good thing so you might as well get the pan/filter replaced and oil changed.
Would be good if you know someone that can scan the code on it, just to minimize any problem you might have.
I can't recall exactly when did the CIC phase in, but I would definitely choose one with CIC.
      02-09-2013, 04:51 AM   #4
recce
recce's Avatar
Australia
23
Drives: 135i & 335i
Sorry...............but what is CIC?
      02-09-2013, 06:51 AM   #5
Ninjaoz
Ninjaoz's Avatar
Australia
79
Drives: E39 540i, E90 320d,F15 30d
2011 BMW 320d  [10.00]
+1 E90 is not that roomy, quite tight to fit 3 in the back.
      02-09-2013, 07:39 AM   #6
_ink
Jedi samurai ninja turtle
_ink's Avatar
Australia
619
Drives: X3 M40i 2018
2018 X3 M40i  [0.00]
CIC is the updated iDrive.
      02-10-2013, 08:10 PM   #7
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
808
Drives: a black car
get an LCI model if you can.
Msport was an option too, pickup an Msport preferably.
      02-10-2013, 10:53 PM   #8
sbce90
Me Boosta
sbce90's Avatar
Australia
249
Drives: 320i / MB C63 / VW up!
As Stu says.. go for an 09 model (LCI) and be on the look out for Msport as well. At some point in 09 or 10 the 335i started to come standard with Msport kit.
      02-10-2013, 11:07 PM   #9
PR3CI5N
need4speed
PR3CI5N's Avatar
Drives: 2010 E90 M 335i
Compare a loaded 08' to a loaded 09' w/iDrive and you'll see the differences. You definitely want a face lifted model. Maybe check into a N54 535i for the family.
N54
      02-11-2013, 05:45 PM   #10
GT1
Drives: 335i
What are some features that distinguish an LCI from a non-LCI?
      02-11-2013, 05:54 PM   #11
PR3CI5N
need4speed
PR3CI5N's Avatar
These threads will give you a good idea. The first thread compares the outsides of the E92's which were face lifted in 2011+ (N55) where as the E90's were face lifted in 2009+ (N54 till 2011). The second thread shows the base model E90/E91's. The M-sports look the best IMO which none of these pics show. For the interior, the new CIC iDrive was added in 2009.
http://www.e90post.com/forums/showthread.php?t=341673
http://www.e90post.com/forums/showthread.php?t=155730
N54
      02-11-2013, 06:49 PM   #12
Zebra99
Zebra99's Avatar
112
Drives: 2011 335is E93
I agree, definitely grab an 09 LCI if you can afford it.
And, definitely get an M-sport
-you'll love the N54
Fuel pump is covers by extended factory warranty and most have already been replaced so I wouldn't even worry.
      02-12-2013, 03:03 AM   #13
LCI has updated headlight and taillights with LED indicators. Bad thing about them is they do fail, and the whole taillight has to be replace, but they are not that expansive, and by this time, most of them would have been replaced.
LCI also has square side mirrors, extra styling lines through tr bonnet, a update tailgate to accommodate the updated taillights.
