F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Still not happy with my brakes
GetBMWParts
      02-21-2013, 06:11 AM   #1
Falafel Combo
Drives: X5 xDrive50i
Stock f30 335i M-Sport package. 1,200 miles.
The dust doesn't annoy me, the squeaking has since diminished, but the brakes are just not grabby enough. It's a bit dangerous. This is a big departure from my e90 330i, which had amazing stock brakes and exhibited great braking control in distressful situations. I am really concerned the brakes on this f30 may perform poorly in the event of an emergency, and I don't want to be the first one to find out. It seems like one would need to I stomp on the brakes with both feet.
Any suggestions?
      02-21-2013, 06:57 AM   #2
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Stange, I think my brakes perform like a boss. I just can't get used to the dusk and the noises. Irks the shit out of me. I have the same brakes as you.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      02-21-2013, 07:12 AM   #3
gator15
Drives: BMW
I did re-delivery at the Performance Center and used a 335i in the driving exercises there. One of the exercises is emergency braking, and the 335i brakes worked perfectly. In the exercise, you speed up to certain speeds (30, 35, 40, 45, 50, 55) and then slam on the brakes as fast and hard as you can and attempt to steer through cones. Believe me, in an emergency your brakes are not unsafe in any way.
I think that your problem is that they do feel very different from the E90. For me, the difference is that there is a little more pedal travel that is needed, which I prefer anyways. However, when you need to stop and slam your foot down, you will have no problems.
      02-21-2013, 07:34 AM   #4
Falafel Combo
Which package? 335i Sport or M-Sport? What are you comparing them to (what's your daily driver)?
      02-21-2013, 07:35 AM   #5
Falafel Combo
How long have you had the car / how many miles? What did you drive previous to your f30?
      02-21-2013, 07:45 AM   #6
jokerswld34
Drives: 2019 BMW M760li
2019 BMW M760i  [0.00]
With the m sport you have the euro pads which have more bite than the US standard pads. The pads are very good, especially when heated up, but I do agree the F30s brake feel is a bit squishier than I like. They aren't unsafe in any way and will work well when called upon. Try bedding them in properly and you'll notice an improvement in performance.
Otherwise, just swap out the pads (to hawks or pagid or something equivalent) and replace the brake lines to stainless steel. That will fix the pedal feel for sure.
      02-21-2013, 08:05 AM   #7
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
I have a AH3 M-sport... I had the absolutely worst "close call" just last week. A car in front of me suddenly stopped at the second of two red lights on either side of a train track crossing. This meant I had to perform the most aggressive street braking I've ever had to do. I was certain I would rear-end the car in front of me. I dug into the brakes, and the car stopped from 30+mph, just inches away from a collision.
The M-sport brakes did just fine by me... and certainly helped me avoid thousands in collision damage.
      02-21-2013, 09:54 AM   #8
ft1338
Drives: None
Nice.... I had a close call once with the junker I currently drive which has no ABS. It was raining and the douche in front of me decided to speed up to catch the light but changed his mind at the last second and stepped on the brakes so hard I skidded all the way up to his FRONT bumper. Yes, front, because I had the reflex to move my car to another lane while skidding with the wheels locked. The little shit looked at me like I did something wrong lol.
Anyway, did you feel the ABS engage in your case and did it work good? I'm looking forward to driving a car with at least minimal safety features......
      02-21-2013, 10:01 AM   #9
SamS
Oh yes, ABS engaged for sure. My car also has Forward Collision Warning system, so a red car icon flashed on the dash and HUD and beeped loudly. I was literally less than 6" away from a crash at 30mph.
There are two traffic lights on either side of a set of train tracks. They are <50ft apart. The first light turned yellow, and we both went through at full speed. The second light was also yellow, but the guy in front decided to stop, which of course I was not expecting. Also, the train was coming through the tracks, so as I'm stopped within inches of the car in front of me, the train is barreling through, now just a few feet behind my car. Scary stuff.
      02-21-2013, 10:05 AM   #10
mikew2069
mikew2069's Avatar
413
I've had my car for almost a month w/ 1700 miles on it. Directly before the f30 I had a 2012 Optima SX and a 2007 Tahoe but I've had experience w/ a bunch of ish.
BM3/H&R/Borla
      02-21-2013, 12:18 PM   #11
ixse
Drives: 2015 boxster s
Stock pads n rotors are more than safe for daily use.. most people don't realize diff cars have diff brake pedal feel. For instance, accord will give much softer brake pedal feel n grab much more with less pressure, vs evo will req much harder brake pedal pressure to get similar stopping (but pressure to friction ratio is much more linear with evo, which helps in modulating braking in racing situations) if you are looking for better initial bite, you need different pads. Ofcourse usually higher perf pads usually have more dusts and noise associated with it. .
      02-21-2013, 07:05 PM   #12
Falafel Combo
So you guys agree that I am exaggerating?
      02-21-2013, 07:07 PM   #13
Falafel Combo
Originally Posted by ixse View Post
Stock pads n rotors are more than safe for daily use.. most people don't realize diff cars have diff brake pedal feel...
Thanks for sharing that crucial piece of field research with us.
      02-21-2013, 07:27 PM   #14
SamS
Well, I only had a single "emergency" so far, and the brakes did perfectly fine. In fact, I was convinced I would have a collision, but I ultimately did not.
I came directly from a brand-new M3. I don't think the M-sport brakes are inferior in any way, for normal street driving.
      02-21-2013, 08:37 PM   #15
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Mine are amazing, and this is with the stock base pads and rotors. Good initial bite.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      02-21-2013, 08:37 PM   #16
shivaswrath
Drives: 2012 335i
      02-22-2013, 06:43 AM   #17
mikew2069
mikew2069's Avatar
413
I wouldn't say you're exagerating. If you're not happy w/ them, then you're not happy w/ them. It could just be the way they are or something could actually be wrong w/ them.
You'll probably have to take it in. Maybe drive another one and see how it feels.
BM3/H&R/Borla
      02-22-2013, 08:08 AM   #18
KellerKiller
KellerKiller's Avatar
Drives: 335i M, EBII, mit alles
Mine feel a bit funny at the beginning of a drive, but that's simply because it's always below freezing at night and the rotors get a bit of rust on them, even in the damn garage. But, once that's cleaned off and they warm up a bit, I have no issues. Hell, sometimes they seem a little too grabby for what I was used to in my e36.
      02-22-2013, 05:45 PM   #19
scott@bmwhn
Drives: Msport X3
Coming from my E90 335i to my F30 328i the brakes had the same characteristics but once I added the Mperformance brakes the initial brake feel definitely softened up. That said, despite the softer initial bite they definitely perform better than the stock setup and were further improved with the addition of SS brake lines.
This is not quite the same scenario as you but it may help
-Scott
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      02-23-2013, 08:03 PM   #20
ixse
No need to be all smart ass about it. Was just trying to give you a little insight. Since when my friends drove my previous vehicle, they thought my brakes didn't work well, but they just weren't applying enough pressure. And yes you sound like you don't know about that crucial field of research.
      02-26-2013, 12:30 AM   #21
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
Brake like you mean it. They will work.
      02-26-2013, 05:59 AM   #22
F555
F555's Avatar
Indonesia
37
Drives: F30 - 335i
Any suggestions?
not satisfied with the standard brake, Me too u r not alone.
So I order me some brembo BBK 6 pot & 4 pot
u should go the same route get u self some serious BBK.
f30post
