BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Coilover Question
      02-24-2013, 05:13 AM   #1
cjt_
Drives: 2007 e92
Coilover Question
Has anyone experienced the clunking sound on the BC ER Coilovers? Anyone know a fix?
I've tightened the top nuts, however I still seem to get the clunking sound on the Front Left of the car.
Many thanks!
      02-24-2013, 05:16 AM   #2
_ink
Jedi samurai ninja turtle
_ink's Avatar
Australia
619
Drives: X3 M40i 2018
2018 X3 M40i  [0.00]
I don't get clunking.. but i get a 'click' when i stop and go into reverse.
      02-24-2013, 03:22 PM   #3
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
162
Drives: E92 M3 2012 Edition 500
BC SHOCKS
I have this system in my car with no issues.
Take it back to the guy that did the fit up and have it checked as the shocks should not bang around.
But there will be some noise as the top mount on the front shocks have a bearing where as the stock system has a rubber mount.
      02-24-2013, 06:18 PM   #4
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
Is it clunking under damper compression or at low speeds when turning?
      02-24-2013, 07:46 PM   #5
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
check the bolts on the strut tower brace, all of them not just the ones on the tower itself, my centre mount (under the little black cap at the bottom of the windscreen) was a little lose and would squeek at certain moments, thought i had picked up a farkn mouse.
      02-25-2013, 04:20 AM   #6
cjt_
Drives: 2007 e92
Occurs mostly on rough roads at various speeds, however it disappears every now and then. Its quite intermittent.
      02-25-2013, 05:13 AM   #7
DR-JEKL
Australia
898
How long have they been fitted for now?
      02-25-2013, 05:36 AM   #8
cjt_
Drives: 2007 e92
2.5 weeks.
      02-25-2013, 06:11 AM   #9
DR-JEKL
Australia
898
2.5 weeks.
Well its most likely not a blown damper...
Have you adjusted the damper settings as they ship them at full hardness?
At full hardness they 'crash' over bumps (a mate got caught out with this on his teins and didnt realise they are set full hard from the factory in the box)
Did you DIY install them (I'm guessing not?) otherwise take the car back to the installer for a quick checkup?
      02-25-2013, 08:59 PM   #10
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
162
My car is set up at full soft for bump and rebound, best to start soft and work up to the hard setting.
OK Pav way you go
      02-25-2013, 09:11 PM   #11
cjt_
Drives: 2007 e92
Nope not DIY, I think thats the next step, thanks guys!
      02-25-2013, 09:39 PM   #12
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
OK Pav way you go
have you got it hard yet
