2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
01-14-2013, 02:40 PM | #23 |
Rep 94
JMH first off thanks for the list!!!
Few questions for you 1. In your browsing have you seen anything that might enable album art over bluetooth? 2. In your sig I see Upgraded B&O, what did you upgrade ont eh B&O system? 3. I also see color matched side and front grill. I did this on my old m5 and liked it a lot, I got it from bimmian. Where did you get yours for your new F10? thanks! |
01-14-2013, 05:12 PM | #24 | |
Internet Crash Test Dummy
334
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
I have not looked for BT audio options as I tend to use my audio snap-in adapter. But I was under the impression cover art should just work over BT I am in the process of upgrading my B&O system and some details can be found here http://f10.m5post.com/forums/showthread.php?t=789195 It's a slow process and hopefully will be completed by spring. As for the painted side grills etc IND are your friends. They offer a complete cosmetic package for the M5 http://f10.m5post.com/forums/showthread.php?t=756017
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
01-15-2013, 12:09 AM | #25 |
Rep 94
Thanks once more for the info! I enabled Wifi and can connect and see my device connected but when I try dnla server on iPhone it and have WiFi selected as source I cannot get sound or videos out of the iDrive. I then tried a computer running windows 7 and a dnla server and though it sees it as connected in wifi in the sources menu it says not connected... hummm What setup do you use? Also I enabled the webserver but when I hit that ip in web browser I can't connect. Still cool stuff!
On the Bluetooth I don't see cover art using the iphone music player or the spotify app. If I attach with USb cable I see cover art in music app but not spotify. I looked around (figured HU_NBT was likely place) but couldn't find anything. This is fun stuff! |
01-15-2013, 12:00 PM | #27 | |
334
Rep 1,055
The webserver might be a setting somewhere else as mine doesn't work either but another F10 works fine (I wonder if they closed the "hole" with the latest sw/integration) . I'll compare CAF files at the end of the week as I won't have access to my coding laptop and the car is in the shop too. Hopefully it's just a simple missing setting
01-19-2013, 08:51 PM | #28 |
Rep 51
Does anyone know if it's possible to get an instantaneous MPG reading in the instrument cluster by pressing the BC button? I read in another forum that it may be possible to code this, but I haven't seen it in any of the cheat-sheets.
Thanks.
* 2021 BMW X7 M50i * 2016 BMW F10 M5 Pure Metal Silver Limited Edition * 2008 Lexus GX470 * 2000 Acura NSX-T |
01-29-2013, 07:44 PM | #29 | |
Rep 602
e92 m3 6MT, RS4 6MT, S4 Avant 6MT, WRX 5MT, Corsica
01-29-2013, 08:50 PM | #30 |
334
Rep 1,055
So after you read you VO and read VCM you then select the module to code and select "Read Coding Data" ,
Then you select 'Edit FDL' , change the value and you save the config (top buttons) and you go back back by pressing top left green (back) arrow button. You should see the FA again and by right clicking select "Activate FA". You should see a green active text next to the FA. Select the CAFD you just edited and select "Code FDL" in the SVT box( right hand middle portion of your UI) Now the coding process should start and complete without error You also may want to power cycle with the ignition switch After you followed all of the above steps it should use the new values
01-30-2013, 12:02 AM | #31 |
Rep 94
So I am able to play DVD video fine on the move with the new settings but I cannot for the life of me get video to play from an old ipod classic that has some videos on it or from a USB stick with some MKVs on it in Divx. I am almost positive I have the settings
HU_NBT -> 3003 -> API_USB_VIDEO --> both this enables the menu selection of "movies" in i-Drive for the USB-Device if you want to play DivX->Xvid contents as well (or Video-cD at that) the following Settings are also necessary. HU_NBT -> 3000 -> ENT_CODEC_XVID --> aktiv HU_NBT -> 3000 -> ENT_CODEC_XVCD --> aktiv Will play any format (mpg, avi, mkv, divx . Also at HD Resolution) But I will check it again. Behavior is the same black screen along with the audio. But assuming I do have that all right is there a format, or codec, or anything special I need to make this work? Also I just noticed today that my HUD Turnsignals that worked fine for a long time have given up the ghost and are no longer there. I have not done any coding since they were added. Anyone else seen this? thanks! |
01-30-2013, 12:05 AM | #32 |
Rep 94
One more question that maybe does not have to do with coding but in the split view One of the options for the right side is BMW Online widgets. Every time I try this I get Unable to establish data connection. Activate Bluetooth data services. I have an iPhone 5 BT connected to it that has data (but maybe not the right BT profile?). I also have an android and windows 8 phone I could try but just not sure what it takes to make it work or if it is even worth it. thanks.
01-30-2013, 10:35 AM | #33 | |
Rep 602
yep, i did all these steps for the other coding i did and it worked fine. but with this mirror folding, what happens is i change the FRM to active, werte=1, then change CAD to active, werte=1 (i need to manually change werte value for some reason), save all that, activate FA, code FDL. then when i go back to read FDL, the CAD reverted to nicht active, werte=0.
01-30-2013, 11:10 AM | #34 | |
Rep 602
also, i don't have the "HU_CIC" category show up on my VCM data for some reason.
01-31-2013, 04:48 AM | #35 |
Rep 852
Looks like someone found a way to disable active sound:
3000 ASD-Configuration - Funktionen - Baureihe to F021 Ref: http://www.bimmerfest.com/forums/sho...d.php?t=672496 |
01-31-2013, 03:01 PM | #36 | |
334
Rep 1,055
01-31-2013, 03:17 PM | #37 |
Rep 1,489
Nice! Going to do this later today.
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
01-31-2013, 05:02 PM | #38 |
Rep 852
01-31-2013, 09:20 PM | #39 |
334
Rep 1,055
the fun part part might be what does the ASD module do once you reach +6000 rpm in "diesel" mode ?
02-01-2013, 03:45 PM | #40 | |
Rep 852
LOL I get your point though... |
02-09-2013, 02:16 PM | #41 | |
Rep 108
Drives: X535d; M2, M3, M5, 540d, AMV8V
Garage List 2016 BMW X535i [0.00]
2015 Aston Martin V ... [0.00] 2015 BMW M4 Convert ... [0.00] 2013 BMW M5 [0.00] 2010 BMW X535d [0.00] |
02-09-2013, 05:04 PM | #42 |
334
Rep 1,055
The "Werte" value is a 'digit/value' so you need to enter the value in the "box" in the lower section and then use the "Apply" button to the right hand (lower portion, little yellow arrow) to apply the settings.
Then save the changes using the save button in the top row From there it's the same process as always, back button , activate FA and code FDL
02-10-2013, 07:06 AM | #43 | |
Rep 108
02-10-2013, 05:36 PM | #44 |
Rep 602
ok I figured it out. default for my car is nicht activ and werte = 1 for CAF. changing to activ automatically sets werte = 0. leave it that way and it will work.
cheers.
