Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Fitting E90 BMW performance exhaust
      03-08-2013, 01:07 AM   #1
Perth335i
Perth335i's Avatar
Australia
Drives: 2008 E90 335i M-Sports
Gents!
I'm chasing some info, I have a cat back BMW performance exhaust for my E90.
The existing system is standard factory.
What needs to be done to fit this? Are any cuts, joins, flanges, v clamps needed to join this up to the existing factory exhaust?
Thanks
Matt
      03-08-2013, 03:01 AM   #2
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
You cut the oem mufflers off and the replacement exhaust clamps onto the oem pipes remaining
With the E90 you have the extra mid section pipe right, so have to cut the oem item also there by using a pipe cutter and then using the supplied clamps to fasten it into place, any exhaust shop should be able to do this easily for you in around an hour.
      03-08-2013, 08:20 AM   #3
Perth335i
Perth335i's Avatar
Australia
Thanks mate, as I assumed from the e92 DIY's. just wanted to be 100% before I started cutting
      03-08-2013, 03:15 PM   #4
DR-JEKL
Australia
898
Post up some pics when you're done
Obviously the system arrived ok!?
      03-08-2013, 06:58 PM   #5
Perth335i
Perth335i's Avatar
Australia
The system arrived just fine, thanks. I'm going to install some catless down pipes at the same time so just sorting those out as well.
After a few other things are installed over the coming weeks I'll post post up a "showcase" thread
      03-09-2013, 03:15 AM   #6
DR-JEKL
Australia
898
Its going to gurgle pop like a mutha now! awesome looking forward to seeing it dude
      03-14-2013, 02:08 PM   #7
xxcferrarixx
xxcferrarixx's Avatar
Drives: 2011 328xi
2011 BMW 328i  [10.00]
Just got my Performance exhaust installed today, your going to love the sound OP.
