Logic 7 Upgrade
05-06-2013, 04:30 PM | #1 |
Rep 4
Logic 7 Upgrade
I have been researching on how to upgrade the logic 7 sound system in my 06 325xi. I just want to make sure I am starting the right way.
First, I am going to replace my amp with a MS-8 with Technic's wiring harness. I am going to keep the stock speakers for now and just get a tweeter for the center speaker. Is this the best way to start upgrading my system, or is there a better way to do this? |
05-06-2013, 05:02 PM | #2 |
1923
Rep 13,131
You need to recode to Hi Fi output for ms-8
You could also consider a mobridge da-2 if you don't want to recode. What are your goals would be a good thing to state so people can respond more correctly to what you want. |
05-06-2013, 05:37 PM | #3 |
Rep 3,969
No need to recode with the MS-8, it sums the L7 amp channels perfectly. Just be aware of the MS-8 drawbacks, like BT echo, turn on/off pops, and reliability. Other than that, in combination with the tweeter addition, best bang for your buck upgrade you can do!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
05-06-2013, 07:43 PM | #4 |
Rep 4
My goals are to increase my systems performance. Not increase to maximum volume, just make it sounds better. I eventually want to upgrade my subs to sws-8s and possibly add a 10" in the back.
Is there any way to fix any of the ms-8 drawbacks? I don't necessarily care about BT, it sucks already. The pops might annoy me, is there any way around that? As for reliability, would it last more than 2 or 3 years? I have also heard that simply getting a better amp for the stock subs makes it sound a lot better. Is that true? If so, what do I have to look for in an amp to make sure it will be compatible. Is there a remote wire I can hook into? Sorry for all of the questions, I just have been trying to track down all of these answers on the forums, but I have been reading so many different things, it's hard to keep it straight. I just want to go into this upgrade with all of the information. Thanks! |
05-06-2013, 07:51 PM | #5 |
1923
Rep 13,131
You might want to read this one
http://www.e90post.com/forums/showth...Vp+electricity
Vp makes some comments about processors in this thread. You can use summing but using and amp to drive another amp of similar size is not the optimal way to do things from a design and efficiency point of view. Did you read this one http://www.e90post.com/forums/showthread.php?t=641323 |
05-06-2013, 08:31 PM | #6 |
Rep 4
Interesting I did not see that M3 thread, but that answered a lot of questions about the MS-8. I realize it is probably not the absolute best choice, but it seems like it would be the most cost effective one at this point in time, seeing as they are going for only 300-400 on eBay.
After reading the other thread, I am still confused about the sub amp. I have heard that blaupunkt is the way to go to power the stock subs and add a little more power to them, but there have been so many different models on different threads that I'm not sure what exactly I am looking for in one. So it's looking like I will want to add the center tweeter, an ms-8, and an aftermarket amp to power the stock subs. I know I will need the harness from Technic. Is there anything else I will need? Also, do you have any suggestions about the aftermarket amp for the subs or do you suggest a different route to go all together? Thanks a lot. |
05-06-2013, 09:31 PM | #7 |
1923
Rep 13,131
Best to talk to Technic
Best to talk to Technic.
He will give you budget wise and common sense council. I would be looking at something that could power some upgraded front doors and floors. Also Technic can sell you all the needed mounting hardware and adapters and other odds and ends I think. The Jl audio XD amps are a standard , known to sound good and are a quality product. These are the most used amps here except for the really high end stuff. Last edited by ctuna; 05-06-2013 at 09:37 PM.. |
05-07-2013, 12:07 AM | #8 |
Rep 5,120
At a minimum you need to amp the front speakers and underseat subs. The MS8 doesn't produce enough power and unless you amp the front speakers it will sound worse than stock.
05-07-2013, 08:19 AM | #9 | |
Rep 3,969
I will agree though that the underseats are not happy with 20W and that they need more power to keep up with the components.
05-08-2013, 05:58 PM | #10 | |
Rep 5,120
And ctuna you do not need to recode in this situation, but you can. I had the ms8 alone hooked up both ways and it was no different. It is simpler just to recode though if you know how to do it. |
05-08-2013, 07:35 PM | #11 | |
Rep 3,969
05-08-2013, 11:36 PM | #12 |
1923
Rep 13,131
Yeah I know its possible its just not koeshser.
no bueno from engineering point of view. |
05-09-2013, 12:32 AM | #13 | |
Rep 5,120
I actually tried having my sub play up to the mids and highs. It was a little bit better, so you might be right about level matching being part of the cause, but I still think it is worth it to just amp the front speakers, and even the center channel. Having more power than necessary is good for sq, you'll never clip or hear distortion. I have Morel Hybrid Ovation II's in the front, and I had each of them wired on their own channel on a xd600/6. Then I tried each front speaker on 2 channels bridged getting 200 watts each, and it sounds much better, everything is just cleaner, even though it got loud enough for me before and sounded great. Anyways from what I experienced with the ms8 it is lacking in power, but maybe I just had my expectations too high for what it is. |
05-10-2013, 04:55 AM | #14 | ||
Rep 206
I've seen a few posts pointing towards this, notably something that Technic said in one of his installs: Quote:
05-10-2013, 11:28 AM | #17 |
1923
Rep 13,131
When you compare power look out for this.
Most car manufacturers will not list RMS power. They will state power but its actually highly inflated and it will be peak power at a fairly high distortion number in comparison to aftermarket amps at least the good ones. So as a guess the actual RMS power on the stock specs is actually half of what is listed. This is further hidden by the fact BMW uses 2 ohm speakers which are not typical and even further skew the power spec as 4 ohm speakers are the more common value. So condsidering these factors for example the Hi Fi I had probably only has 12 watts RMS at 2 ohms on the door channels. When I put in and XD600/6 its running at 100 watts rms on the same speakers. |
05-10-2013, 02:14 PM | #18 | |
Rep 5,120
The DA2 should be an improvement. I've seen Ken recommend it quite a few times, so it must be good. If you can afford it, do it. |
05-10-2013, 02:19 PM | #19 |
Rep 5,120
