BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > For those running meth(map 3) + G5 board...
      05-13-2013, 11:27 AM   #1
LAZ
OneThirty5Eye
LAZ's Avatar
Drives: 135i, 335i
Couldn't find info on this on any of the forums, so I had to email Terry.
Thought starting a thread would benefit future users with the same question.
For those running meth (map 3) + G5 board...
What do you guys have your additive set to?
What do you guys have the boost failsafe psi set to?
Default failsafe is set to 18 psi , which may be too low for anyone running a 60 additive.
Terry informed me to set mine to 20 if I run a 55 additive. That would put me at around an 18 psi target, which would give me a 2 psi cushion.
Just wondering what additive people are running with the new G5 + meth/E85 mixes or those who run both meth + E85 mixes, since G4 board was really only able to support a 40 additive.
Im thinking of running a 55 additive when on meth and doing a 60 additive if i ever run a 30/70 E85/93 mix + meth....
What do y'all think?
      05-13-2013, 01:13 PM   #2
Shadow007
Drives: 2009 335i coupe monaco blue
I just had my meth kit installed this past weekend and I have the additive set to 30, for the G4 version, which puts me at 17 psi.
F90 M5 Comp/ FI Exhaust, MAD pdownpipes / PG Intakes/ H&R Springs/ AG wheels
E85 Z4M
      05-13-2013, 01:17 PM   #3
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
can you please post a log for a run where meth flows, and have IAT in the log
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      05-13-2013, 01:30 PM   #4
LAZ
OneThirty5Eye
LAZ's Avatar
Drives: 135i, 335i
I think a 30 additive puts you at ~16 psi target...
      05-13-2013, 02:14 PM   #5
tofu-
87
Drives: 335i Jet Black/Coral Red
100% meth on 93 octane
60 add
      05-13-2013, 02:20 PM   #6
LAZ
OneThirty5Eye
LAZ's Avatar
Drives: 135i, 335i
60 add
So what do you have your failsafe set to? 20psi?
JB4 G5//BMS DCI//BMS 3" CATELESS DP//BMS Meth Kit//BMS Backend Race Flash//Alpina B3 Flash//
Walbro 450lpfp//Yokohama SDrive//BMS SLD//N55 Midpipes//Vibrant Performance Resonators
      05-13-2013, 02:21 PM   #7
Shadow007
I hit 17psi today after I finally set the JB4 and meth controls up correctly. http://www.n54tech.com/forums/showthread.php?p=159161 According to Coolingmist instructions, I would still need to drive the car some until the system "learns", I guess my driving style or what ever and yes I will post a log.
E85 Z4M
      05-13-2013, 02:39 PM   #8
LAZ
OneThirty5Eye
LAZ's Avatar
Drives: 135i, 335i
Yea, the system learns and adjusts itself. It adapts to IAT, fuel octane, mods, outside temperatures etc. Are you running the meth with 93 oct and the JB4 Failsafe box? I am running the FSB meth controller and I believe the correct meth flow scale setting is 60 if you are running the FSB...and a 40 additive is a good starting point if your using 93 oct.
      05-13-2013, 03:05 PM   #9
tofu-
87
Yes
The base target of map3 is 12 and change I believe.
      05-13-2013, 03:17 PM   #10
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I run 80 Additive (N20 sensor) with a 23 psi overboost safety. Keep in mind I have supporting mods to run this as well as 65% E85....need octane for higher boost.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      05-13-2013, 03:21 PM   #11
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Here is a log on "ISO 20"
      05-13-2013, 03:52 PM   #12
LAZ
OneThirty5Eye
LAZ's Avatar
Drives: 135i, 335i
Yea, RB turbos are several months down the road for me. Have you done a 1/4 mile with your current set up? Also, what kind of exhaust do you have? I didnt spot one in your sig..
      05-13-2013, 04:15 PM   #13
oshusttoley
Drives: 2008 335i sedan
I use add. 35... And boost safe at 18. Don't want to push my stock snails too much. I'm happy with 17psi boost. I sent my logs to terry and told
Me I can make add 50 or 60 when I use e85 too.
// JB4 ISO // Running Meth // Full FBO // E85 user //
      05-13-2013, 04:59 PM   #14
dfjaws
dfjaws's Avatar
Drives: E90 M3 / E86 M Coupe
I run a 40 additive on 93 octane with the failsafe at 19psi.
After seeing some other posts, I'm thinking I could do at least a 50 additive if I up the meth content. Currently I'm using 60/40 meth/water by weight.
      05-13-2013, 10:35 PM   #15
oshusttoley
I use -20 ww fluid with no additives and add a bottle or two of heet per gallon. Really cheap. 2 bucks for ww fluid and 1 dollar for heet at Walmart. Plus this mixture, will never have to worry flashing or catching fire if leaked
      05-14-2013, 01:00 AM   #16
tofu-
87
35 additive shouldn't be 17psi
should be more around 15.5-16
      05-15-2013, 01:31 PM   #17
oshusttoley
imm full fbo on too...
      05-15-2013, 03:07 PM   #18
triggz
56
Drives: E92 335i
base is 12psi. 35 ad would be 15.5psi-16psi max.
I'm on a 60add and i'm 17.5-18psi
      05-15-2013, 03:38 PM   #19
Shadow007
I'm using the CMGS/VC2 controller with FSB on 93 oct. So are you telling me I could increase the additive from 30 to 60 and not mess anything up? What would increasing the additive improve? According to the jb4 g4, I'm only good for 16.5psi, but I did hit 17psi on a short sprint which I reverified with my vent gauge.
E85 Z4M
      05-16-2013, 07:55 AM   #20
triggz
56
Drives: E92 335i
You can only increase the additive if you're running a higher concentration of meth. I'm running 60add because I'm using 100% meth. Your timing should also be increasing above 10.
      05-16-2013, 08:24 AM   #21
LAZ
OneThirty5Eye
LAZ's Avatar
Drives: 135i, 335i
ok, if your using the CMGS/VC2 then the settings you have are correct for starting off. The settings that i mentioned are for the JB4+FSB ... Guess it is different. Since with JB4+FSB our meth flow scale is 60 and additive is 40, which is 4 psi increase.
      05-16-2013, 01:21 PM   #22
Quebequer
Drives: BMW
Base is 12.8 psi.
So 35 add will be 16.3 psi.
2008 BMW 335xi MT e90
JB4 G5, WW meth kit, turbonetics intercooler, DCI, UR catted dp's, UR catback, koni yellow + H&R springs, Rieger front bumper, Avant Garde 19" wheels
Tags
additive, failsafe, g5 board, jb4, meth
