Underseat Midbass tuning question
05-15-2013, 04:08 PM | #1 |
Rep 440
Background info:
Iv'e upgraded my HI FI system to the following Amp is a JlAudio xd600/6 gains all set at 1/8 of dial Fronts: Morel Hybrid Ovation II ch1-2 (75w) Full range from amp... Morel crossovers in doors set to default jumpers Underseats: Kicker SSMB 8"Ch5-6 Bridged (150W) LP 150hz Rears: Stock ch 3-4 (75w) hp at 150hz my end result is to have an ear bleeding SQ System im almost there So here's the questions... After installing the under-seats im having a hard time dialing in the mid bass and keep out low end (poping) which option is better; buying a pair of Bass blockers for 150hz or get another amp? my next question... I will also be getting a corner sub 10" (id10 or jlaudio 10w 6) still havent decided but , if i get a second amp ideally i would like to find a 2 ch mono amp to run the corner sub and the under seat. is there something like this available? if you need photos i can provide later today Thanks |
05-15-2013, 05:46 PM | #3 |
Rep 2,547
How are you doing this anyway?? Isn't bridging the underseats taking up 4 channels and you have the other 2 for the morels, where are the other 2 coming from for the rears?
Also I think you have to high pass the morels even though you have the crossovers. I think that crossover is for the mid to tweeter, not a high pass for the morel mid. |
05-15-2013, 09:41 PM | #6 | |
Rep 440
no there is a Neg and a Pos for each Ch
As for the Morel Crossover Ive leared that The crossovers that came with the speakers are designed for the speakers. You will either a) destroy the speakers eventually or b) not get all the sound the speakers can possibly be getting, if you use the amp crossover. i Run the amps flat and let the crossovers the speakers came with handle it. Quote:
05-15-2013, 10:04 PM | #7 | |
Rep 5,120
05-16-2013, 07:39 AM | #8 |
Rep 401
I would definitely high pass the fronts...around 150hz no higher than 200hz, see what sounds good to you.
I'm not sure how you have the underseats bridged. But I would ditch the rears and bridge the underseats differently. I have the same amp and have my underseats bridged, I'm using ch's 3 and 4 for my left underseat and 5 and 6 for the right one. With Y adapters. I also have a subsonic filter on the underseats at 50HZ. I have different underseats though and dont know how low the Kickers will play clean. I'm using a processor for the sub sonic but I'm pretty sure you can set up a high pass filter on the amp for the underseats. I just realized I used the word underseats about 10 rimes in one paragraph! |
05-16-2013, 10:52 AM | #9 | |
Rep 2,547
For example the left underseat would be hooked up to channel 3 Left+ and channel 4 right - and the right underseat would be hooked up to channel 5 left+ and channel 6 right -. You take up 4 channels to bridge for 2 speakers. |
05-17-2013, 02:05 PM | #10 | |
Rep 440
would it best to add an MS-8 at this point to control and shape the sound or use Bass blockers. Im a Little apprehensive to add an EQ processor after my alpine imprint i used a few years back. Im appreciating all the feedback you guys are telling me |
05-17-2013, 06:00 PM | #12 |
Rep 5,120
I would put each speaker on its own channel. It only makes sense you have 6 speakers and 6 channels.
Those speakers are most likely 4 ohms and you are probably wiring them in parallel, which would give you a 2 ohm load. That amp is only stable down to 4 ohms bridged. You can bridge each one on its own, but then you have to use 2 channels for each underseat sub. If you don't mind not having rear speakers, go for it. |
05-17-2013, 07:10 PM | #13 | |
Rep 4,121
My opinion: 6 speakers, 6 channels. The woofers are slightly more efficient than the morel anyway so you will not have a problem matching levels Cross @ 150-200hz Do not under or overlap. |
05-20-2013, 07:16 AM | #14 | |
Rep 401
If you're front stage is set up correctly you don't need the rears, which is how I'm running it. Peoples opinions on rear fill differ. |
05-20-2013, 10:08 AM | #15 | ||
Rep 4,121
That being said, i did run my old setup just as described (fronts on 1/2, midbass on 3+4/5+6) |
05-20-2013, 11:58 AM | #16 |
Rep 5,120
It will sound much better when you stop clipping channels 5-6, trying to run a 2 ohm load bridged. When you cut the impedance in half you double the power, when your amp is already giving all its got, you are just clipping.
I actually have my morels bridged (2 channels each), and my underseats are just on one channel each, so I agree with Taibanl that you don't need the extra power for the underseats. |
05-20-2013, 01:21 PM | #17 |
Rep 440
I reverted back to CH 5-6 on the under seats and its better. I have to fiddle with the gains to level match.
i might try to disconnect the rears on the XD600 tonight and give the fronts a bump. |
05-20-2013, 02:37 PM | #18 | |
Rep 401
I'm using cdt's in the doors and Jehnerts. I bridged them to blend in better with the CDT's. But it seems like the Morels need alot more power, although I don't know the sensitivity of either the Morel or the CDT's. But like BMW...said the 2 ohm load isn a good idea. |
05-20-2013, 02:48 PM | #19 | ||
Rep 4,121
Don't get me wrong though 75w is plenty of power for them. |
05-20-2013, 10:51 PM | #20 |
Rep 5,120
I would do an Alpine PDX-V9 powering the Morels bridged (200watts), and the trunk sub(500 watts). The xd600/6 powering the kickers bridged(200watts), and the rear speakers(75watts).
By having both of your underseats on the same channel you are losing out on stereo separation. I'm not sure if many songs take advantage of stereo midbass, but you said you were after sq. |
05-21-2013, 07:56 AM | #21 |
Rep 401
Yeah I just checked mine...91.1db...I also checked the Kickers and its sensitivity is also at 88db? How would that affect his setup?
05-21-2013, 09:25 AM | #22 | |
Rep 4,121
In YOUR case, the Jehnert is a bit more efficient, but not quite as much as the CDT so you could go either way (bridged or single channel). |
