Shielded rca wiring
05-16-2013, 06:29 AM | #1 |
Rep 405
Shielded rca wiring
If you want to have shielded rca hu to amp cable for your wiring to mitigate any noise then where do you guys connect shield to? Ground at both the ends? or leave it disconnected?
650i F12 - HUD, 6WA, SLI, Logic 7, Dynamic and Adaptive Drive, Comfort Access, Soft-close, top-view,
Previous X5 40d M Sports and 535d LCI |
05-16-2013, 05:42 PM | #2 | |
111
Rep 1,951
That said, it's probably pretty pointless with fully differential twisted pairs, as in the OEM wiring. The only noise I've ever heard is some engine squeal, and that's only at super high volume (listening to quiet talk radio from the iPhone) and it wouldn't be helped by shielding. And that's with an iPhone running LTE full blast, sometimes many at various locations in the car (passengers). If anything were going to cause noise that could be mitigated by shielding, it'd be cell phones.
05-16-2013, 06:37 PM | #3 |
1926
Rep 13,134
There is no problem with the twisted pair setup
There is no problem with the twisted pair setup.
Its designed to suppress noise . If you have an amp or processor that accepts the signal you shouldn't have a problem . The problems I have seen on noise here generally are a bad grounds, bad head unit ,or non compatible amp and gains set wrong. If you have and RCA connected to a radio output the shield is a live signal. The Jl audio amps auto detect this and use the signal accordingly. |
05-17-2013, 09:06 AM | #4 |
Rep 405
In my case output is BMW CIC in hifi coding, I am in process of tidying up the wiring a bit so got rid of old transparent ones (it was different requirement then) and laying new wires, now since they are brand new wiring I thought I would go for shielded ones, also the signal is low level so doesn't need thick gauge wiring.
Normally for shields cic gives dedicated pins (like for all fbas signal) so was wondering where can I connect newly laid cable's shield. Thanks for the answer guys, I would club them all up and connect to the cic chassis, better then leaving then dangling.
05-17-2013, 10:11 AM | #5 | |
Rep 9,097
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
05-17-2013, 10:12 AM | #6 | |
Rep 9,097
- your amp accepts differential balanced input - you are using shielded twisted pairs - coded to hi-fi - not using LOC - Proper earth then you should not have any noise. You do not need to earth anything. Cure the things only, if you have problems.
05-17-2013, 10:22 AM | #7 |
1926
Rep 13,134
If you extend the RCA cable with balanced signals
do not allow the shields to touch each other as they are live seperate signals. It would be a good to insulate them with some tape . Some RCA extension cables have insulated shields some don't. |
05-17-2013, 02:05 PM | #8 | |
Rep 4,121
05-17-2013, 05:00 PM | #9 |
Rep 405
All the way from CIC to the boot mounted MS-8.
05-17-2013, 05:55 PM | #10 |
2312
Rep 13,023
05-17-2013, 06:55 PM | #11 |
Rep 4,121
For what its worth. I have been working on my noise issue with VP-Electricity and we suspect I am picking up noise along the harness run due to lack of twisted pair in the technic harness.
If you run twisted pair RCA you should be ok. |
05-18-2013, 04:50 AM | #12 |
Rep 9,097
What he said.
I ran normal wires in my first upgrade with hi-fi coded hu and picked up noise. So I ran shielded + twisted pair of rca in 2nd upgrade and never had any issues since then.
05-19-2013, 02:28 AM | #13 | |
Rep 405
Btw. does all shielded wire come as twisted pair inside, what sort of guage wires do you guys go for and with what kind of sheild (braided metal or foil)
05-19-2013, 03:16 AM | #14 |
Rep 9,097
Afsar
Not all of them are twisted pairs and shielded. I have used different brands on my car and I prefer; 1- Audison twisted / shielded (£25) 2- Knukonceptz twisted / shielded (£20 delivere) Actually few days ago I sold 4 channel Knukonceptz at a bargain price. I guess you hardly visit UK classified. There are cheaper stuff out there but would not go for them.
05-20-2013, 10:59 AM | #15 | |
Rep 4,121
05-20-2013, 02:30 PM | #16 |
Rep 9,097
Not sure about your side of the continent but here in Uk, there is not a lot of difference in the price of both, so opted for shielded.
Shielded gives it another level of protection from any interference. From different experiments, I have noticed that sub frequencies are least likely to pick any noise. Since I am running 4 way active system, therefore I selected 4 different pairs of rcas. One is Audison, two different types of knoukonceptz, and ordinary untwisted pair. Last is used for sub frequencies. All the installation which I do, I run a track of black noise to make sure there is 0% noise in the sound system. So far it has worked 100%.
