Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > XI to RWD
      05-22-2013, 10:58 AM   #1
09E90utah
Drives: 2009 335i x-drive
XI to RWD
I saw this on another forum. Have you guys tried this?
After working on DPFix code clearing I may have stumbled on a way to make an XI fall into RWD only mode for a day by causing steering angle adaptation error.
1. Reset adaptations via JB4 or other methods
2. Allow ECU to sleep
3. Press start with foot off brake - again so all lights on dash on but not running
4. Press gas pedal to floor and back off to learn pedal (failure results in busted idle at startup)
5. Do not move steering wheel - press start and press brake
6. Vehicle starts and throws codes as shown in attachment
7 - enjoy RWD mode
8 - When done, park and cycle steering wheel fully side to side
9 - Go to sleep
10 - Wake up to AWD car again - all error codes are cleared
I've done the above a few times now but never actually tried pushing hard enough to see if it was true RWD mode or not, as the AWD codes scared me until I figured out why they were happening.
Thoughts? Anyone want to try this out or tell me why it's a horrible idea before I do?
      05-23-2013, 12:29 PM   #2
Quebequer
Drives: BMW
First time I hear about that. Usually people just unplug a fuse in the fuse box to achieve RWD on xi's. But that sounds interresting.
2008 BMW 335xi MT e90
JB4 G5, WW meth kit, turbonetics intercooler, DCI, UR catted dp's, UR catback, koni yellow + H&R springs, Rieger front bumper, Avant Garde 19" wheels
      05-23-2013, 01:13 PM   #3
reeltime
Drives: 2015 M4
Yeah most people go the fuse route. If this works, it would be pretty cool!
2015 AW/SO 6MT F82 M4
      05-23-2013, 01:46 PM   #4
Baine
Drives: 2008 335xi Coupe
How does the fuse work? Just take it out and it is RWD like the standard 335i? Or do other things not function normally?
Does the traction control get thrown off?
Does it harm anything?
This could be fun.
      05-23-2013, 02:46 PM   #5
Amini77
Drives: Alpine White '13 550i
2013 BMW 550i  [0.00]
This could be fun.
Traction control turns off, ABS, flickers spazz out, windshield wipers, etc. Well at least for my 330i. There's a thread somewhere here on it. It isn't that bad, just fun for a few blocks doing donuts with lol. Not sure what fuse you 335 guys have to unplug.
      05-23-2013, 06:06 PM   #6
Boosted-M
Drives: F10 535D XDrive (USA)
Everything bugs out but is certainly fun!!
Here are the 2 fuses to pull:
      05-23-2013, 09:40 PM   #7
dkexige
dkexige's Avatar
62
Drives: E90 M3, 8J TTRS
^ Unnecessary picture feat unlocked!
      05-24-2013, 02:17 AM   #8
ColdTestament
Yep.
Drives: 1999 Tahoe z71, 2011 e90 m3
OP, was your jb4 still functioning and increasing boost with your method? when you pull fuses i hear the jb4 no longer works.
thanks.
      05-24-2013, 10:35 AM   #9
bwc13
Drives: F30 340i Sedan
2017 BMW 340i  [0.00]
Is there any difference betweeen this method and the fuse method, specifically the wipers going full blast, lights, etc. Is there any way to avoid all that? thanks
      05-24-2013, 12:41 PM   #10
09E90utah
I just saw this on another forum. I haven't tried it yet but seems simple enough to try. I'm a manual but assume the operations are the same.
      05-24-2013, 06:56 PM   #11
Boosted-M
thanks.
Correct. When the fuses were pulled the jb4 loses power...I removed the jb4 and successfully made the car rwd with Cobb only
      05-25-2013, 01:10 AM   #12
drGK
drGK's Avatar
Drives: e92 335 xi
I think this is something that could be done electronically (tune, code etc. ) someone seriously should look into it..... It would make the 2wd guys jealous as fffff
      05-25-2013, 06:18 AM   #13
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
Turns out this is way harder than one would think, there are couple of long threads on it if you search.
      05-25-2013, 12:58 PM   #14
drGK
drGK's Avatar
Drives: e92 335 xi
It will be one of the coolest and must have options for us awd drivers. If it ever gets done :/
