fuel tank ring
05-29-2013, 07:59 PM | #3 |
Rep 715
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
05-29-2013, 09:50 PM | #5 |
Rep 182
Took me a real long time to get it off, but it eventually came off. Make sure after you get it off to inspect bit the ring and the O-ring. I put my old one back on and when I filled up my tank all the way it leaked a lot... I took it back off and found a slight cut in both the screw top and the O-ring. $15 later for a new screw top and o ring it was perfectly sealed
05-30-2013, 10:24 AM | #7 |
Rep 160
Drives: 2007 335i coupe
I has having a hard time also.
I sprayed WD-40 into all the holes so it would soak into the threads. As soon as I was done I tried giving it another wack and it came off immediately. Good Luck |
05-30-2013, 11:33 AM | #8 |
Rep 715
Try my home made tool , makes it sooooo easy....
Square aluminium profile cut at 15 cm mark 13 cm between center holes where you fit two M8 bolts. Voila .... it was EASY!!!
05-30-2013, 11:41 AM | #9 |
104
Rep 1,529
why dont you show us in action...it would make a lot more sense to us noobies.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
05-30-2013, 12:03 PM | #10 |
Rep 715
Basically the bolts touch where the tabs are , so on both sides there is a bolt pressing on the tabs , you apply force with the lazy arm and ring comes of super easy.
I will take some more pics so its easier to see what I mean.
05-30-2013, 12:16 PM | #11 |
Rep 715
Here you go , hope this makes it easier
Pictures show how to use the tool for taking off the ring , and use of lazy arm to get proper force on the tool.
05-31-2013, 03:28 PM | #12 |
119
Rep 1,525
Since I got everyone's attention I might as well let you guys know. I did get the ring off and did the swap out with 455lph. Now for all that are going to use the PLASTIC T from McMasters make sure you push ALL hoses ALL the way on do not leave any room all. I left a little room where I could still see some white on the T I clamped very tight and it kept slipping off. I broke down several times until I got the hose all the way on and reclamped. Just a fair warning for all thats all. I am planing on using the brass T as I think the metal T provides a better bite when the hose tries to slip off. Just a thought I know Terry says it's not e85 compatible but.... In my tank I will not run 100% E85 it will be a mixture.
06-06-2013, 08:01 PM | #13 | |
Rep 1,449
JB4 G5, VRSF catless DPs, FMIC, BMS DCI, Muffler Delete, Alpina B3 Flash, RB Turbos, BB Race Flash
06-10-2013, 11:10 PM | #15 |
119
Rep 1,525
Just broke down again this time the hose did not slip off the T ! The expensive $30 gator hose from ORielly's didn't hold up and it had a big tear in it. I had been driving around a few days with just crappy 91 in the tank. As soon as i put e85 in the tank the hose lasted about 2hrs. I went to a local shop here and picked up e85 hose $15 per ft the looks really promising and I will be pulling the bucket out and installing the new hose tomorrow. I can get any one the same deal shipped this stuff is no joke if anyone wants some I have pics on my cell that I can send you just text me 505 908 4916........ it's better than spending $30!
06-10-2013, 11:31 PM | #16 |
Rep 182
Just curious where the line ripped for you? Could it have gotten caught up from binding somewhere in the bucket? It would be nice of we could just buy some of the extra stock orange fuel line that is used with a reducer or something to fit over the Venturi since we know that would stand up very well
06-10-2013, 11:37 PM | #17 |
119
Rep 1,525
true would be nice! I am going to give this blue stuff a try and see. It really can't get any worse! It ripped right below the T couldn't see it to well as I took it apart on the side of the road but i will take pics and post them tomorrow.
06-10-2013, 11:42 PM | #18 |
125
Rep 2,172
02-24-2019, 03:25 AM | #20 |
Rep 6,285
I removed mine using a set of large multi grips.
So easy using this method, hammering didn't work for me as you cant get the right angle with a large screwdriver (its applying force in a downwards orientation v's side load) |
