Vibration When Driving
06-10-2013, 02:49 PM | #1 |
BD_e92
358
Rep 1,748
Whats up guys, about 3 weeks ago i hit a pothole and got a flat tire on the front driver. My tires are continental dw staggered 235/35 and 265/30.. I swapped the tire for a new conti got a wheel alignment.. Since the new tire and wheel alignment my steering wheel vibrates at higher speeds and it seems to still pull hard to the right. Any ideas what i should check? Is it a bad wheel alignment or could i have done damage to the suspension when i hit the pothole?
06-10-2013, 02:51 PM | #2 |
13
Rep 342
Drives: E90 Monaco Blue 335i xdrive
could either be suspension related or a bent wheel. I currently have a slightly bent wheel from a pothole. Still drives perfectly straight though but the wheel does shake at higher speeds.
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
06-10-2013, 02:58 PM | #3 |
Rep 3,386
it is most likely the wheel balance that is off. you dont get vibration from a bad alignment. an easy way to determine if the wheel balance is off is to see if the vibration is only at certain speeds.
06-10-2013, 03:03 PM | #4 |
Rep 3,854
Drives: 330i, 135i
06-10-2013, 03:06 PM | #5 |
BD_e92
358
Rep 1,748
Well i know that the wheel i hit the pothole with is definitely not bent because i had it inspected when they mounted and balanced it on the new tire however i did hit a pothole with my right front and didnt get a flat.. Guess im going to have to go get that one checked out too
06-10-2013, 03:08 PM | #6 | |
13
Rep 342
06-10-2013, 03:17 PM | #7 |
BD_e92
358
Rep 1,748
06-10-2013, 03:21 PM | #8 |
BD_e92
358
Rep 1,748
06-10-2013, 03:43 PM | #9 |
BimmerPost Supporting Vendor
2042
Rep 25,989
It sounds like one wheel is slightly bent to me. It could be suspension related but I'm thinking that if the vibration is rotational it's safe to assume it's a wheel. Might not be the same one that the tire blew out on though.
VMR|Wheels | 714.442.7916 |
06-11-2013, 08:20 AM | #10 |
Rep 3,386
so you feel no vibration at 50mph? if i were you i would go to a bmw dealer with a Hunter roadforce balancer and get the wheel re-balanced.
http://www.gsp9700.com/search/findgsp9700.cfm you can use that to see who has one
