Escort New Release of Passport Max Radar/Laser
06-11-2013, 01:43 AM | #1 |
No 55mph
1623
Rep 8,479
Just a heads up:
Escort just released their brand new detector Passport Max HD yesterday. Higher sensitivity than the 9500iX, greater range, User selectable multi-color Graphic OLED display, all features of 9500 plus more. Price is $549 but if you trade in a 9500 detector they give you $120 off the price Just picked up the newest model for $429, plus since I was one of 1st 1000 to buy, got 4 yr warranty instead of 2, lifetime firmware upgrades, double the Escort Live subscription. I've been following it's pre-release for a couple months now on RadarRoy & other sites. So if you're looking to upgrade your 9500iX - it's worth $120 toward the new model. And the new detector uses the very same Smartcord (or Direct-Wire Smartcord) as the 9500 - so no need to re-wire thru your dash. It comes with the better design one large suction cup mount that is specific to the new model. https://www.escortradar.com/passportmax/ https://www.escortradar.com/passportmax/max-video1.php Here's link to a reply of the Passport Max Launch Webinar from yesterday: http://www.radardetector.org/escort-max-launch-replay/ According to independent testing done by Speed Measurement Labs & RadarRoy, the new Max has:
Operating Bands X-band 10.525 GHz ± 25 MHz K-band 24.150 GHz ± 100 MHz Ka-band 34.700 GHz ± 1300 MHz Laser 904nm, 33 MHz Bandwidth Radar Receiver / Detector Type Superheterodyne, Varactor-Tuned VCO Digital Signal Processing (DSP) Laser Detection Quantum Limited Video Receiver Multiple Laser Sensor Diodes GPS Receiver SiRFstar III Display Type Graphic OLED CruiseAlert™ Bar Graph ExpertMeter™ SpecDisplay™ 5 Levels of Brightness with Full Dark Mode User Features Display Color Speed Display (On / Off) Cruise Alert Over Speed Meter Tones AutoMute (On / Off) AutoLearn (On / Off) Units (English / Metric) Voice (On / Off) GPS (On / Off) AutoPower Bands (Selectable) Markers (Selectable) Clear Locations Auto Calibration Circuitry Mute, AutoMute and SmartMute Power Requirement 12VDC, Negative Ground Escort SmartCord® Included Sensitivity Control Highway, Auto and Auto No X Compact Size 1.3" H x 3.2" W x 5.3" L
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-11-2013, 11:58 AM | #2 |
I'll get back to you
7570
Rep 2,132
http://www.radardetectorforum.org/sh...ad.php?t=23667
Seems the sensitivity is between the M4 and M3 horns and around the V1.
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
06-11-2013, 12:29 PM | #3 |
No 55mph
1623
Rep 8,479
Good link - the response time shown in the vid for Instant On is unbelievable
Didn't seem to have any problem with simultaneously tracking (2) Constant On + a POP added in for good measure with same response time Looks promising - as it seems the unit they were testing was a prototype from a couple months ago & not a production unit. Course there's always room for continued improvement with the 'Lifetime Firmware Updates' I got for being in 1st 1000. My 9500 had lost the mini USB port that's used to connect for updates & Defender Database updates anyway. Was gonna cost $130 for full refurb, so it was a choice between fix the 9500, go with RL, or the Max - decided to go with the new dog...
06-11-2013, 01:58 PM | #4 | |
7570
Rep 2,132
this may be the wifey's new RD.
2018 Stinger GT
07-25-2013, 04:52 AM | #5 |
No 55mph
1623
Rep 8,479
OK, just got in my new Max & installed - here's my initial impressions compared to 9500iX:
Unit
Display Pros:
Cons:
Mount Pros:
Cons:
Escort Live Smartcord Power Hookup Previously w/9500iX I used the Remote Hardwire Smart Cord with the remote conceal mounted in ashtray - which fit nicely. This time I went with the Escort Live Smartcord which entailed having to re-wire the car as it has different way of connecting & the remote unit is too large to fit in ashtray Pros:
Cons:
Sensitivity Hard to really say as I've only used it so far during drive in today, but I have it set in Auto ranging mode which bases the unit sensitivity on your current speed (slower speeds set to City/higher set to Highway). Many business alarms along the way in to work which usually show up as X band false alerts on crappy detectors without good filtering. It only showed (1) false X Band while the 9500iX had shown quite a bit more until it auto locked out the falses. You can get rid of X Band alerts all together by selecting the Auto noX mode which is nice. > So basically, for me, even though the display is 'prettier' & shows more info - I find the xtra info really irrelevant & of no use. All it does is make the actual alert portion smaller & harder to read for these 52 yr old eyes > Also, due to the OLED display vs. the 9500iX display - it is not nearly as bright or eye catching during an alert, so listening to the alert tones is more critical, which you may or may not hear over the radio if you listen at very loud music levels. What would be nice is if someone could come up with a RD that actually breaks into radio sound & alerts thru car speakers similar to cell phone operation when paired with car. > The constant scanning bar across top of alert portion is annoying as you constantly see movement on alert screen - while with 9500iX when you saw ANY movement on display it caught your eye - as it was an alert of some type. > The optional Smartcord Live is really of no use to me, don't need the real time location map as I have NAV, can't hear the audible phone voice alerts over the radio, can't see the visual alerts unless phone is staring you in the face, not gonna fumble around with the phone while driving trying to mark locations for others on the Live network. I would much rather have just stayed with the regular Smartcord remote... Not unhappy I purchased this unit - just gonna take some time getting used to the smaller, not as bright, alert text
07-25-2013, 11:16 PM | #6 |
Rep 119
Good review, I will be checking back for some updates.
________________
Current: 2020 Jeep Grand Cherokee - Limited X - Hemi V8 - Fully Loaded - White - 35% Tints Sold: 2011 E92 335i xDrive 6spd Fully loaded BSM on Cream / Gloss Black Grills / 35% Tints / Debadged / Red Rpi scoops |
