Should I be worried? transfer case/Rolling diameter/xdrive
06-18-2013, 09:19 AM | #1 |
Mr. Monaco
155
Rep 4,197
So I am about to mount a new staggered setup on my pre lci e92 xi and am somewhat worried because the tire sizes I need to run are different than what's been on the car for a majority of it's life.
I am coming from a staggered 19x8.5/19x10 setup with the common 235/35 265/30 tire setup. However my new wheels have a little more aggressive offsets and I think I need to run a stretched tire to clear fenders. So my question is should i be concerned that my transfer case may act up after putting on the new setup? I've heard it could confuse the system and cause issues. The new tires will be 225/35 and 255/30.
06-18-2013, 09:29 AM | #2 |
GoofBall
50
Rep 1,055
Keep the tire diameter as close as possible. I forget the amount you can variate front to back but keep it as small as possible. You can run any widths you want, just keep the overall tire diameter the same. Tire rack makes it easy with Rotations per mile listed for tire sizes on the site.
06-18-2013, 09:50 AM | #4 | |
Mr. Monaco
155
Rep 4,197
06-18-2013, 11:19 AM | #6 |
BimmerPost Supporting Vendor
2042
Rep 25,989
You should be fine. I would recommend familiarizing yourself with 1010Tires tire size calculator, where you can input the year/make/model/trim and plug in what you're looking for.
http://www.1010tires.com/Tools/Tire-Size-Calculator
VMR|Wheels | 714.442.7916 |
06-18-2013, 11:26 AM | #7 |
General Nuisance in a Private Conveyance
77
Rep 1,907
Drives: like it's rented
Here is another link to check the min/max wheel width a certain tire size will fit:
http://www.rimsntires.com/specs.jsp IMO, the fronts/backs that come closest in 19-inch wheel diameter are: 225/35/19 Front; 265/30/19 Rear, or 235/35/19 Front; 275/30/19 Rear Cheers!
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570 |
06-18-2013, 11:39 AM | #8 |
Mr. Monaco
155
Rep 4,197
guys, this isn't about the rolling diameter as I stated. I know how to use the calculation tool for keeping the percentage in check.
I am more so concerned with my transfer case acting up because my car has adapted to the current tire setup, 235/35 and 265/30. This user had an issue I am talking about http://www.e90post.com/forums/showthread.php?t=832909
06-18-2013, 11:54 AM | #9 | |
181
Rep 1,681
Looks like he went outside the tolerance by switching rear tire size. Different companies size tires slightly differently. So for him, 275 may have been just within the range, but going to 265 and stretching slightly which will drop the diameter some messed it up.
You may have a problem, you may not. Quote:
06-18-2013, 12:24 PM | #10 | |
77
Rep 1,907
So, did you check to see what the 235/265 ratios look like on 19-inch rims? According to the calculator above, 235 wheel diameter is 25.48 inches or nearly 25 and one half inches. The 265 wheel diameter is 25.26 inches or nearly one quarter inch less in diameter. While the specs are within one percent, the difference may adversely affect your transfer case because they are not rolling at the same revolution. Best bet would be to have the following specs, as I said earlier: 225/35/19 Front; 265/30/19 Rear, (25.2 inch Front/25.26 inch Rear) or 235/35/19 Front; 275/30/19 Rear (25.48 inch Front/25.5 inch Rear) 235/275 are the best choice overall for x-drive. Now that you see the numbers, you can make an informed decision and the reason why any other combination will screw up the transfer case on an x-drive setup.
06-18-2013, 12:40 PM | #11 |
GoofBall
50
Rep 1,055
You keep saying what its not about. You don't understand the mechanics of the parts in questions. They do not adapt or have any indifference of what tires you have on there. As long as they have the same rolling diameter. The front and rear gears and transfer case will do the same job they always do regardless if you have a 21" tall tire or a 44" super swampers. I think you are over complicating this in your head or you really have no idea how these parts are only mechanical.
Its 100% about rolling diameters being the same, no more, no less. Overall size will have no bearing at all on what those parts do. It will only affect speedo because the car calculates speed with rotations per mile and the odometer. Unless you get a tire that wont fit, then its the body that will disagree. Quit assuming things and look at every post in this thread. Also the thread you posted is because he did in fact have the wrong size tires as the rolling diameter did not match within the tolerance. The car doesn't care as long as they are the same height. |
06-18-2013, 12:43 PM | #12 |
2042
Rep 25,989
OP, we are recommending those tools because we've known setups like that to work without a hitch, and when it comes down to it, it's all about the rolling diameter. If you stick within the right percentages, and pay attention to the height of the tires, you will not have a problem.
06-18-2013, 12:59 PM | #13 | |||
Mr. Monaco
155
Rep 4,197
06-18-2013, 01:02 PM | #14 | |
Rep 985
Drives: 2008 Porsche 911 Carrera S
RSI, LLC | Fender Rolling | Suspension | Engine | Other Stuff
06-18-2013, 01:14 PM | #15 |
Mr. Monaco
155
Rep 4,197
