BMW Style 95 Front Tire Size Question
06-19-2013, 11:50 PM | #1 |
Rep 496
Hey guys,
I know there are a million thread out there about style 95 745i oem wheels fitment, but no one seems to have tried to run 245/30 up front. Is this possible on a 07 335i? I know I may have to run spacers but I'm just wondering. Ill be running 275/30 in the rear and I've heard I'm fine with rolled fenders which I have. The sizes are 19x9 and 19x10 et24 all around. Can someone shed some light on this?
07 BMW 335i (East Lansing, MI)
Winter / Sport / Premium Packages Installed |
06-24-2013, 07:00 PM | #4 | |
Rep 496
A 235 will be slightly stretched which isn't too bad. It will make it for sure fit inside the wheel well without rubbing.
06-25-2013, 07:35 AM | #5 |
Rep 1,464
Drives: 2009 BMW 335xi
Are you lowered? Pretty sure you will rub pretty bad with 245s in the front without some added camber and trimming away some problem areas of the plastic liner. I am lowered on eibach pro kits with ~ -1% camber on 19 x 8.5 et30s with wider 235/35s and I had to trim the liner on both sides. The 19x9 et24s stick out about 7 mm further than my wheels. I think that 235/35s work well with the style 95s on stock suspension but 225/35s or more camber or both may be required on a lowered car.
06-25-2013, 09:00 AM | #6 |
Rep 199
Hello, I'm running, 225/35/19 and 255/30/19 on those wheels.... Essentially closest to stock sizes. At stock height i rub in the rear over dips, i need to get my fenders rolled. If you plan on running spacers and lowered, You may have to run narrower tires... Have a friend running 235 in the rear and a 30 spacer slammed to all hell
With rolled fenders, 255 or 265 would be good... With the offset of these wheels, they are dead on flush with the fenders Last edited by Nguyenhu0106; 06-25-2013 at 09:06 AM.. |
06-25-2013, 09:43 AM | #7 | |
Mr. Monaco
155
Rep 4,197
06-25-2013, 11:13 AM | #8 |
Rep 496
I'm not lowered at all. Stock sport suspension with rolled rear fenders. If fenders are rolled I shouldn't bottom out on a 275/30 rear should I
06-25-2013, 09:31 PM | #9 |
Rep 199
I have an e90, at stock height (Sport suspension) and on large dips.. or when im hauling alot of people... it's not bad but i hear it... I plan on lowering it next year but i definitely need to roll my fenders |
