255 vs. 265 rear tires, which one works better with 225 front tires?
06-28-2013, 10:34 PM | #1 |
20
Rep 365
hey guys, i'm trying to decide which setup works better with my wheel.
I'm getting 19x9 front and 19x10 rear, would 225/35/19 and 255/30/19 work better, or would 225/35/19 and 265/30/19 work better for all wheel drive? less rolling diameter differences? Some say 255 some say 265, but I want to ask the experts here to be sure. Thanks |
06-29-2013, 10:19 AM | #2 |
Rep 734
255, don't want to keep the front and back too different or else it'll star to induce understeer as well as problems with traction control sometimes. (i might be wrong xD, but that is what i think). Good Luck!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
06-29-2013, 01:14 PM | #3 | |
General Nuisance in a Private Conveyance
77
Rep 1,907
Drives: like it's rented
I am no expert by any means, but with the wheel widths you have, 225 in the front might be a stretch, unless, of course, you want that setup. I have attached a handy link: http://www.rimsntires.com/specs.jsp This will not only tell you everything you want to know, it also gives the minimum and maximum wheel widths for each tire size. With that said, while 225F/255R work pretty much in 18 inch, you will have a really stretched look front and back due to the 9x19F/10x19R setup. Looking at the link, you will discover that the max safe width for 225 is 8.5 inches, in either size (18 or 19s). On the other hand, the max width for 255 is 9.5 inches, whereas at 265, the max width is 10 inches, and the rolling diameter is even closer front to back (225/265). If you want to play it safer, try 235F/275R because they are nearly perfect front to back. IMO, I would go with 235/275 first, or 225/265 if you don't mind a mild stretched look in front, unless you get Michelin Pilot Super Sports, which are pretty meaty tires, to begin with.
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570 |
06-30-2013, 09:12 AM | #4 | |
Rep 531
07-01-2013, 02:21 PM | #5 | |
BimmerPost Supporting Vendor
2042
Rep 25,989
235/275 are very close in height, if that matters to you OP. What offsets are your wheels?
VMR|Wheels | 714.442.7916 |
07-01-2013, 08:39 PM | #6 |
Rep 26
Hey guys,
I have a question that is somewhat related to the OP's question. I would create another thread, but I can't since this is my first post. Anyways, I recently got some of the F10 M5 replica rims that are 18x8 and 18x9. Both are ET+35. From what I have read, I could go with 2 tire setups: 225/40R18 255/35R18, or 235/40R18 265/35R18. Which setup would be best? I have a 2008 328 e90. |
07-01-2013, 09:12 PM | #7 | |
77
Rep 1,907
When I switched to meaty Micheline Pilot Super Sports, I went back to OEM specs at 225/255, because they filled the wheel and the well and were less expensive than the plus sizes.
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570 Last edited by flip4335; 07-02-2013 at 08:08 AM.. Reason: adjusted rear tire specs |
07-01-2013, 10:14 PM | #8 | |
20
Rep 365
et24 for front and et15 for rear. I'm going with 225f and 255r. |
