M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      06-29-2013, 01:08 PM   #1
whiteM5
Drives: 2013 M5
Turner axle back and now car feels sluggish
So had the Turner axle back installed yesterday and now the throttle response seems slower, acceleration feels slower, etc.
I checked the vacuum lines and they are plugged and have no idea where else to look?
Anybody else experience this?
*BTW sound is awesome but sound isn't worth loss of performance.
      06-29-2013, 01:33 PM   #2
h4nh
h4nh's Avatar
Drives: 09 SC E90 M3 / 13 F10 M5
2009 E90 M3 (superc ...  [10.00]
2013 M5  [0.00]
Same here.. Just installed eisennman race axle back. I wonder if it takes the computer time to adjust? Or makes no difference?
It feels like it was faster stock. Lol
      06-30-2013, 04:34 AM   #3
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
I have power throughout the rev range. Don't know what your talking about.
      06-30-2013, 08:19 AM   #4
bmellion
bmellion's Avatar
Drives: 2020 M5
Could it be possible that the ECU needs to re-adjust? I'm getting the E-Race axel back installed on Monday and would like to know?
2020 BMW M5
2014 BMW M5 Competition Pack, Dinan Stage 2, Full Eisenmann Race, MSR Intake and lots of carbon fiber...
2013 BMW X5M, Dinan Exhaust, Dinan Stage 1, Dinan Suspension (gone)
2013 BMW M6 Eisenmann Race(gone)
      06-30-2013, 09:38 AM   #5
Bmanny
Bmanny's Avatar
Drives: Beamer
I have had the Turner Muffler since about 500miles. The car felt slower at first now i am at 1800 and feels great. Give it a few 100miles to adjust
      06-30-2013, 10:20 AM   #6
Niko1414
Drives: 720S, s550, S7, 997GT3RS
Dyno only way to really know
      06-30-2013, 01:10 PM   #7
RPiM5
RPiM5's Avatar
2870
Drives: Black M5
The ECU needs at least 300-500 miles to adjust. U do in fact gain horsepower with the Turner setup.
For my catless downpipes it took 500-1000 miles to adjust.
      06-30-2013, 01:47 PM   #8
h4nh
h4nh's Avatar
2013 M5  [0.00]
I got to open my car up in the country roads today and all the power was there. I think it's the drone at low rpm that makes it seem like it's sluggish.
      06-30-2013, 03:12 PM   #9
LI-M5
Drives: 2016 M5
I put turner on the other day , besides sound there was no diff !!!
Anyone thinking bout turner should def do it !!
      06-30-2013, 04:19 PM   #10
boots
Curve Thrasher
boots's Avatar
623
That's good to know it works properly.
      06-30-2013, 04:26 PM   #11
stealth.pilot
Knight Commander
stealth.pilot's Avatar
United Kingdom
559
Drives: 2014 911 Turbo S
I read somewhere that the active exhaust valve control increases torque at low rpms. Apparently at low rpms, closing the valve on one outlet increases backpressure which increases torque at low rpms until there is enough backpressure then the valve opens.
So by deleting the valves this product and the race exhausts slightly reduce low end torque. however the difference is small enough that most people don't notice.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      06-30-2013, 08:46 PM   #12
LonghornM5
Drives: MCB, DCT, Turner, iND, invisbr
I was going to respond here but started a new thread w/ my dyno.
Mine doesn't feel sluggish at all.
      06-30-2013, 09:03 PM   #13
ColdList
ColdList's Avatar
152
Drives: McLaren 675LT / C7 Z07
Guys, it is your exhaust vacuum lines not properly plugged. Ridiculously common problem when people install aftermarket exhausts on the F10. They can't just be crimped or tied off. Go to Auto Zone and get some RTV sealant for $5 then do the following:
1. Locate your lines at the rear of the car near where you mufflers are (likely they have been tucked away by your exhaust installer)
2. Find a "plug" that is a tiny bit larger in diameter than the inside of the lines. A screw will do but a solid plastic or metal plug works best.
3. Coat the plug with RTV and inset the plug inside the lines firmly, MUST be TIGHT. No air can be escaping the lines whatsoever.
4. Coat the top of the plug at end of vacuum line with RTV and let it dry for a couple of hours.
Problem will be fixed. Car will run like new. :-)
Trust me. I have helped others with this and I know this first hand because it happened to me. :-) Car feels as if it is a non-turbo when they are not plugged properly. In most cars you can simply crimp the lines and tie them off with zip ties. Not so on the F10 turbo motors. There is no ECU resetting or anything computer related. The problem IS the vacuum lines. Many installers don't even try to tie them off. They simply disconnect them from the valves that come standard on the OEM exhaust (look at your old exhaust and you will see them on the sides of each muffler. There are small nipples where the vacuum lines were secured to them before) and since there are no valves on the aftermarket exhaust, they simply tuck them away and you leave with a car that feels like it has lost all torque.
Best of luck!
Mike
      07-01-2013, 04:35 AM   #14
brainblade
Drives: 2016 x5m
Coldlist post makes sense. BUT i do believe droning exhausts make the car feel slower at lower rpm. I had the problem on my e60 with Eisenmann race. After going back to a stock system my view is that the race exhaust systems are not well calibrated for low rpm city driving and give you the bogging out sound a lot. Doubt your car is slower. Your just matching your selections to offset drone.
      07-01-2013, 09:51 AM   #15
ColdList
ColdList's Avatar
152
100% with you there.I should have been more clear. If you have the vacuum line probs then you will DEFINITELY know your car is slower. It will literally feel like you have lost your turbos. If you just sort of "feel" it is a little bit slower then it is probably you hearing those low end bogging out sounds. I found this to be the case on my two Eisenmann systems even after fixing my vacuum line problems. It is almost that the car just "sounds" slower because you hear the noise at low end when you first touch the gas pedal.
      07-02-2013, 03:08 PM   #16
AlphaAlpineM6
AlphaAlpineM6's Avatar
Drives: 2014 BMW M6 & 2012 AMG CLS63
Best of luck!
Mike
What Mike said.
2008 M3 Sedan + catless + Tune
2012 CLS63 AMG
2014 M6 Coupe + catless + KW V3
2015 Porsche GT3
, 2015 M3, all stock, 1/1 Space Grey
      07-08-2013, 08:41 PM   #17
noushy
///M Fan
noushy's Avatar
1657
Drives: M8 Comp, X5M Comp, iX M60
Mike not all aftermarket systems have vacuum delete, the Akra have the vacuum lines just like stock!
Noushy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown
2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22
2023 Audi RS6 Avant Daytona Gray/Black
2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order
      07-21-2015, 03:11 PM   #18
Thunder43
Thunder43's Avatar
10
Drives: 2013 F10 M5
I know this is an old thread but thought my experience may help some folks. I just installed the turner and also experienced some sluggishness. I was surprised as I specifically made sure the tech capped the lines with the supplied rubber caps after reading this post.
I resealed the vacuum tubes myself to get a tighter seal...it was like a whole different car. Back to new. Night and day. TIP: I would not rely on just the rubber caps- that come with kit. Properly seal the hoses immediately!
2013 M5 BSM/SS - BMS Stage 1, Turner Race Exhaust, 12mm spacers, KW HAS, Dinan sway bars, IND cosmetic package, LED kit, V12 coded
      07-21-2015, 08:23 PM   #19
Mgone
56
Drives: X5
Simple,
put 2nd gear
2k rpm then floor it to 6500
3rd gear same thing
4th gear same thing
do it like 5x each. so computer adapts to new found pressure from exhaust
      07-22-2015, 11:50 PM   #20
shahin
169
Drives: 18 M5 FE,15 M6 GC, 12 M5,06 M5
Make sure the vacuum hoses for the stock exhaust are plugged.
Use some window silicon and a screw or nail.
You guys are loosing boost.
Some aftermarket exhaust don't have the butterfly valves that close and open with stock exhaust. And if you don't plug them after installing new exhaust you will loose power.
      07-28-2015, 04:40 PM   #21
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Drives: 2013 BMW M5 | MSR Stage 3
Shahin is correct - you need to plug the vacuum lines. I had same exact issue. Once plug, all that power is back!!! Experienced this first hand.
I went to autozone and picked up Vacuum plugs and a band clamp and sealed them both off.
      01-12-2016, 06:29 PM   #22
jahdish
Insta pjahdish
Drives: 18 BMW M5/BMW X6/Ferrari 458
So I just had my Turner muffler delete installed today. Looks great and sounds great. There is some drone in the 1.5-2k zone but not bad. I may be a bad judge of normal tolerance as I recenlty drove an 800 mile road trip driving a f430
Scuderia and that didn't bother me
Now the bad - My M5 feels sluggish now. The installer crimped and zip tied and on the way home I felt it was definitely not pulling close to normal. I left the crimp and zip tie and added a plug and just took out for a drive. Unfortunately it feels the same. I feel like it's a dumb question but I will ask it anyways - is there any chance that the vacuum tube being crimped is hurting my cause? Any help is greatly appreciated.
m5post
