Updated jb4; low boost now
07-10-2013, 09:10 PM | #1 |
Rep 84
I just updated my jb4 g5 iso to the most recent firmware which is #23. While I did this, I also changed Future Use B to 2 and Fuel Open Loop to 75 due to the 29F2 and 29E2 codes I was getting. Those were the instructions from BMS if you are getting those codes. I test drive the car and no matter what map, it was only getting 7-8PSI, I'm guessing stock boost. Any ideas?
07-10-2013, 10:02 PM | #4 |
Boost For Fun
Rep 32
Check what map your on.
09 335i Coupe JB4 G5, Meth, DCI
08 335i Sedan 12.035 at 118.14 1.92 60 foot JB4 Meth CM5, M10 Nitto NT05R on K1's, SOLD. |
07-11-2013, 02:41 AM | #6 |
Rep 925
I was getting 7-8 psi in every map using the latest firmware, but here is my story. I updated the firmware, drove straight to an e85 gas station and put in 40% e85. I got on the highway immediately and tried map 7 for the first time.
It hit 17+ psi, then around 5000rpm, psi dropped to 7-8 psi all the way to redline. After that no matter which map I chose, I couldn't go above 7-8psi. I pulled over, turned off the car, then restarted right away. Same thing. I pulled over again, but this time let the car sit about 5-10 minutes then got back on the highway. Put it to map 5 and it started hitting normal boost again. I'm really not sure what exactly happened and how it fixed itself, but maybe your car will be fine tomorrow morning? |
07-11-2013, 03:37 AM | #7 |
Rep 7,377
is the ses light flashing ? that seems like a failsafe is triggered
07-11-2013, 05:22 AM | #8 | |
Rep 84
07-11-2013, 05:50 AM | #9 |
Rep 229
Drives: 2013 335is E93
what mods do you have? maybe increase your failsafe to 19.
07-11-2013, 09:01 AM | #11 | |
Rep 84
07-11-2013, 09:27 AM | #12 |
Rep 229
