My car has very abnormal starts...
07-11-2013, 12:57 PM | #1 |
72
Rep 702
Sometimes it would literally start as soon as I would push the button, sometimes it would delay a few cranks and then fire up (with a bit of ruffness). Today was very strange, it cranked for the longest time, and finally started after maybe 5-6 cranks... What can be the problem?
07-11-2013, 01:32 PM | #2 | |
Rep 3,625
07-11-2013, 01:49 PM | #5 |
Rep 3,854
Drives: 330i, 135i
Sounds to me more like fuel pump issue...keep us posted.
07-11-2013, 01:53 PM | #6 |
Rep 7,377
leaky injector: happens almost only when car is left overnight and cold start. can smoke, missfire and smell gas .
hpfp: happens on a regular basis, cold/hot start . gets worse and worse till it dies and you cannot run the car anymore
07-11-2013, 03:56 PM | #9 |
Rep 5,448
I had one fuel pump that just had long starts, usually after it sat, started out once in a while, then almost every morning, then even after it sat for a couple hours it would get long starts. BMW tried to fix this in newer software by pre priming when you open the car door, so the issue is less apparent and happens less often, but eventually you get some long starts as it gets worse. Otherwise the car always ran like a top and never threw any CEL's. The next pump never had long starts with the updated software but started throwing CEL's when using a lot of throttle, so they can fail differently, but it does sound like a fuel pump issue in yours potentially. If it was injectors or plugs, it would start fine but miss or run rough, if it is a long start, the engine is not getting fuel in any cylinder for a period of time.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-11-2013, 04:45 PM | #10 |
Rep 6,136
