Smoke From Exhaust - Turbo Seals? Video Inside
07-12-2013, 02:41 PM | #1 |
Rep 3,625
Found this video of my car leaving cars and coffee from a few months ago and noticed the smoke coming from the exhaust? Does this look like the turbo seals are on the out?
Skip ahead to the 4:30 mark. Last edited by JStang; 07-12-2013 at 02:59 PM.. |
07-12-2013, 05:22 PM | #4 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
If it was oil it would have white puffs of smoke....not dark colored as shown in the video P.S. Car looks and sounds great!
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
07-12-2013, 05:28 PM | #5 |
Rep 3,625
I have catless downpipes but secondaries are still there. I did two pulls an hour ago and the first pull produced smoke and the second did not. I am experiencing some long cranks both with and without e85 so I may have a leaky injector. Would this cause the excess fuel causing the smoke? AFR's looked good after reviewing logs.
07-12-2013, 05:37 PM | #6 | |
105
Rep 1,133
Just thinking out loud...I think with a leaky injector it would be difficult to maintain good AFRs.... If you suspect its the injectors maybe try stopping by a dealership and see if they can scan the injectors to see if they can be replaced under the recall....Shouldnt cost you a dime and at the same time they can check your HPFP since your having long cranks...Just find a mod friendly dealer or else
07-12-2013, 05:39 PM | #7 |
105
Rep 1,133
Also I heard if you have a leaky injector...When you pull the spark plugs after the car has been sitting overnight...You should be able to tell if the spark plug is wet
07-12-2013, 05:55 PM | #9 | |
Rep 6,136
Leave the car overnight, and pull the plugs in the morning. If any are wet, that cylinder's injector is leaking. If it's been leaking for awhile the plug will be black as well. |
07-12-2013, 05:57 PM | #10 | |
Rep 6,136
I've also found that it's very hit and miss. These injectors can last thousands of miles, or a few hundred before they start leaking. |
01-06-2014, 06:13 PM | #12 |
Rep 488
Drives: 2008 335xi E90
Any codes?
MHD Self-Tuned Scaled FlexFuel Map | M-Boost | N20 Tmap | Helix IC | Fuel-It Stage 2 LPFP | BMS DCI | BMS Thermostat Delete | CP-E Charge Pipe | Tial-Q BOV | Apex Arc-8 Hyper Silver | Michelin PSS | Cool Carbon Brake Pads R/T | SS Brakelines | ECS 2-Piece Rotors F/R | xHP Stage 3 | xDelete Sport | KW-V1 Coilovers | Turner Strut Brace | Lux Angel Eyes | CF Kidneys | Scoops
01-07-2014, 03:45 PM | #14 |
Rep 3,625
Yeah I probably have an injector leaking. I need to pull the plugs and figure it out soon. AFR's seem fine but I get rough cold starts often.
01-07-2014, 07:02 PM | #15 |
Rep 2,661
black smoke is fuel and white some is oil so your good
01-08-2014, 02:31 PM | #18 |
Rep 911
Injector... You can cross check by smelling your exhaust when idle... another cross check is to see if you use a more then normal amount of fuel on average...
Smells spicy/sharp... when idle
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
01-08-2014, 04:36 PM | #19 |
Rep 1,434
looks like unburned fuel and where were all these cool cars off too?
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
01-08-2014, 07:11 PM | #20 |
Rep 42
When you are burning oil it will be blue smoke coming out, white is when you have coolant leaking in the head gasket and the one is normal as it was not black smoke which is too rich. Hope this helps.
01-09-2014, 06:57 AM | #21 |
Rep 3,625
01-09-2014, 03:55 PM | #22 |
Rep 719
Blue tinted smoke is oil... White smoke is usually water or condensation and dark smoke is fuel.
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
