07-13-2013, 12:13 AM | #1 |
Rep 214
K&N for F10 M5
I think K&N just released F10 M5 replacement air filters! Yayyyy!!!!
http://www.knfilters.com/search/prod...x?prod=33-2488
I hate M Cars!!!!!!!!
E46 M3 S71 X6M F10 M5 |
07-13-2013, 04:38 AM | #3 |
Rep 2,523
Ordered
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
07-14-2013, 09:10 AM | #4 |
Rep 2,523
http://item.mobileweb.ebay.com/viewitem?itemId=130923259860
07-14-2013, 06:26 PM | #6 |
Rep 1,425
What are the advantages to using the K&N versus stock?
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
07-14-2013, 07:17 PM | #8 |
Rep 1,291
thanks for the link, btw, did you have to order 2 or they come in a pair already?
Must stop eating..............
07-14-2013, 08:25 PM | #9 |
Rep 2,523
Come as a pair
07-29-2013, 04:25 PM | #10 |
tico12
Rep 70
Can someone address whether changing to K&N will provide any change in sound or performance.
Otherwise, why would anyone consider switching? Surely not for longevity |
07-29-2013, 08:09 PM | #11 |
Rep 2,523
Installed mine. More intake sound, feels like a bit more throttle response, but it could be the placebo effect. Definitely think these will be more effective than stock.
07-29-2013, 11:49 PM | #13 | |
Rep 1,489
I would think that if you over-oil them, yes. Saw a great tip somewhere (can't remember where) to keep you papers, and when you clean and re-oil keep the filters out of the car for a bit. Having the paper filters allows you to drive while the oiled filters are out.
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
07-30-2013, 01:09 AM | #14 |
127
Rep 1,622
Are the K&N's oiled?
Anyone open a set up yet?
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
07-30-2013, 09:01 AM | #16 |
Rep 646
I just installed the K&N air filters over the weekend. A few notes:
The last screw in the back corner of the air box on the driver's side is a major PITA and took an hour to get out by itself One of the filters was drenchied in red oil. inside the plastic bag it came in. I had to dry the filter and left it out of the package to dry out a bit. I feel like my car lost some low-RPM throttle response when I put my Supersprint racing mufflers on about a month ago. After installing the filters, it felt like the throttle felt as responsive in the low-RPMs as it had previously. |
07-30-2013, 09:08 AM | #17 | |
Rep 1,341
Drives: 2013 M5 SSII
07-30-2013, 10:30 AM | #18 | |
Rep 2,523
07-30-2013, 10:43 AM | #19 |
Rep 646
I was there when the lines were plugged and I don't think that was it. The car seems powerful in all the rev range except for the throttle tip-in. The filters seem to have restored that feeling... but it may be all psychological..
07-30-2013, 10:45 AM | #20 |
Rep 214
I have used K&N in all my cars and never had a MAF sensor issue. That being said, you do have to make sure that the filter is not drenched in oil when puting it in the car. I would usually drop the filter onto a cardboard on the floor to shake off loose oil and take a rag and wipe it down in general before putting it in.
As for making a difference? Yes it does, but minor. It definetly flows better then stock paper filter. It make more of a difference when it you really need it such as at WOT/ high RPM. A little secret. That sticker that comes with it? It's worth about an additional 32 hp when you apply it to the correct spot on the car.
07-30-2013, 10:49 AM | #21 |
Rep 214
I do notice that putting an exhaust on the f10 M5 does change the characteristics of the the HP/Torque curve a bit. You will loose a bit of torque between 1000 to about 2500 rmp range. It will feel like you lost a bit of that initial throttle response feel. If you go to Akra's site and look at the chart, you will see the reduction in torque at that range. You will ultimatley gain peak HP and Torque but you will loose some in the low range. It's more pronounced depending on how you drive how heavy your foot is .
08-11-2013, 09:25 AM | #22 |
Rep 13
The other option is the BMC filters. Both the BMC and K&N are essentially the same filters...gauze type with a filter oil. The K&N may be a little cheaper though.
I've had the BMC filters installed for a while...no issues with the MAF. Tom |
