From Nitto NT 555 to Michelin PSS
07-14-2013, 02:17 PM | #1 |
469
Rep 4,392
Car: 2011 DCT 335is
Wheels: 19" BMW 313 Style Tire Size: 235/35/19 front; 275/30/19 rear Had the Nitto NT 555 for 1.5 years. When I first got them from day one the car pulled slightly to the right. AS the tires aged, more mileage, more wear the pulling to the right got worse. After about 10 months I started to notice vibration over 70+ mph, and as more wear it got worse. I had alignment checked three times from since I had them. the first month I had them, 10 months later after owning them, and then again on 7/12/2013. Same results, nothing wrong with alignment. I even had my tires balanced, still pulling to the right, still vibration, and.....more road/tire noise I got fed up and decided to pull the trigger on some Michelin PSS. Got them installed on 7/12/2013. The pulling to the right is gone, vibration is gone, tire noise gone....it rides like how a BMW should ride...smooth Since its two early with the PSS I can do a comparison about what the experience is between Nitto and Michelin Road Impact Absorption: When hitting a bump etc the impact is very sharp on the Nitto's where as the shock end up absorbing most of the impact. The Michelin the impact is more bold absorbing most of the impact compared to the Nitto's. The Michelins are more comfortable when it comes to road impact 100% Handling: I thought the Nitto's had good handling but I had to fine tune the tire pressure to 32psi-front and 35psi-rear just to get it right. If the recommend tire pressure on the driver side door is added, the handling is horrible regardless if it is filling with air or nitro. After the install off the PSS, I checked the tire pressure and sure enough they filled it up with air based on the BMW specs. I was nervous at first about the handling. After a few minutes of driving and pulls the handling was spot on. Later I filled up the tires with Nitro. Wet Road: The Nitto tires were ok when new, as they got wear steering on a wet road became a concern as many times I had to slow the car down to the point where I was comfortable and safe. Even when new hitting a puddle I can feel car lose traction a bit. The Michelin experience in the rain, reminds me of driving a X5 that plowed through the wet road and puddles like they weren't even there. Was able to drive speed limited in extreme rain fall and never felt uncomfortable about the handling. The car always had traction even when ripping through water. Road Noise : Michelin PSS does 100% better over the Nitto NT 555 I will update this thread with more progressively, especially when I do track comparison....stay tuned |
07-14-2013, 03:52 PM | #3 | |
469
Rep 4,392
I probably wont be out to the track till next month technically. I dont want to force wear the tire till then, but will update this thread for sure. As of right now, the rears have not even skipped a beat on my acceleration so far. I am gradually breaking them in |
07-14-2013, 07:30 PM | #4 | |
Rep 3,625
07-14-2013, 07:47 PM | #5 |
Rep 236
I swapped out my PZero runflats for PSS after 4,000 miles and never looked back. On a hot day, they are like glue wrapped around my rims. Even running the stock pressures, the ride quality was greatly enhanced.
2011 TiAg 335is -->2015 Range Rover Sport
07-14-2013, 11:11 PM | #6 |
DIYER
614
Rep 5,521
This has me really thinking if the vibration I have is a my slightly bent rim or the tire wear? My car pulls to the right also even after a alignment. I have never hit a pot hole or anything.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-14-2013, 11:32 PM | #7 | ||
469
Rep 4,392
If your car was pulling to the right from day 1 then the tire has/had conicity or the straight line stability in the threading is off which causes tire pull For everyone readying this make sure to get your tires "force road balanced" at least every six month if you do "a lot of mileage" on your car if you have a staggered setup. If you don't then at least once a year |
07-15-2013, 12:14 AM | #8 | |
DIYER
614
Rep 5,521
07-15-2013, 04:34 PM | #9 | ||
388
Rep 1,945
07-16-2013, 07:53 AM | #11 |
Rep 3,625
I decided to go with Hankook V12's. The more I thought about it, I only go to the track a handful of times per year and they should be more sticky than my General G-Max's. I just couldn't justify the extra jack though I'm sure it's worth it if you go to the track often.
07-16-2013, 02:51 PM | #12 | |
469
Rep 4,392
So far I came to two emergency stops on wet road and the tires never buckled. They are expensive no doubt, and since I do track bi-yearly, and it rains here bi-yearly they were the best choice I have heard great reviews about the Hankook V12 and they are a great performing tire. Congrats and enjoy. |
10-12-2013, 12:24 AM | #13 | |
Rep 648
Drives: 2012 335is
2012 E92 335is | BSM/Coral Red | Moonroof Delete | 6MT BQ Tuning | ar design DPs | M Performance Spoiler | Michelin PSS | Cyba Ram Air | VRSF CP | Fuel-It! Stg 2 LPFP Split Armrest | LUX Reverse Lights | Rear Fog Lights Enabled TOOK DELIVERY 24 OCT 2011 [FIRST PICS] [INTERIOR PICS] |
10-12-2013, 03:29 AM | #14 | |
469
Rep 4,392
285 for the rear may clear with no rub, it looks like I got more room since the 313 style rims do a great job of being tucked in Over all the PSS tires are above my expectations, especially in the rain |
10-12-2013, 04:31 AM | #15 | |
Rep 648
Drives: 2012 335is
The PSS will be my next summer tire. Thanks for your help!
10-12-2013, 11:09 AM | #16 | |
469
Rep 4,392
I have stock suspension, the rear is already lowered, just need to drop the front a bit more For suspension though I am going with Eibach Coil Overs HERE and an alignment kit for proper proportion |
10-12-2013, 11:40 AM | #17 | |
Rep 648
Drives: 2012 335is
I looked at Michelin's website, they don't make 285/30/19. The closest sizes are 285/35/19, 295/30/19, 295/35/19 What do you suggest? I often have my wife and 2 year old son in the car with me as well.
10-12-2013, 11:44 AM | #18 |
DIYER
614
Rep 5,521
I have 245/295 PSS and love it!
10-12-2013, 11:49 AM | #19 |
Rep 648
Drives: 2012 335is
Do you have any rubbing issues? Are your fenders rolled?
10-12-2013, 12:01 PM | #20 | |
469
Rep 4,392
The stock height for the rear is low enough unless BMW did something different with the 2012 + 335is |
10-12-2013, 12:11 PM | #21 | |
Rep 648
Drives: 2012 335is
10-12-2013, 12:18 PM | #22 |
469
Rep 4,392
Absolutely no complaints on the 275/30, no rubbing at all. You are perfectly fine with those, however 275/35 based on my review you will rub with extra weight
