Devils own 300 psi pump adjustment question
07-15-2013, 11:54 AM | #1 |
DIYER
614
Rep 5,521
Need a bit of info on the adjustment of this pump. I believe I adjusted the pressure up once (1/4th turn clockwise) then yesterday I turned the adjusting screw a 1/2 turn maybe more and forgot I had already adjusted it previously lol! I need to know if this will hurt anything because on the "devils own" site it states 1/2 turn turn is 300 psi. I need to know how many turns is full psi from the starting point (screw turned clockwise turning pump down). How many turns from starting point to 300 psi.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-15-2013, 12:03 PM | #3 |
DIYER
614
Rep 5,521
I did but haven't got a answer yet, u don't want to blow the seals lol! Well the screw just stop, it did not do that. This sucks. Well just in case do you have a 300 psi DO pump lol!
07-15-2013, 12:08 PM | #4 | |
3441
Rep 79,211
I would go back to what you think is stock setting. I would highly recommend you let your methanol set up be. You change things too much. Enjoy your car If you need a car to work on I get a supercharger kit I need installed on my Z06 ha. |
07-15-2013, 12:52 PM | #5 | |
DIYER
614
Rep 5,521
07-15-2013, 02:01 PM | #6 |
3441
Rep 79,211
07-15-2013, 02:04 PM | #7 |
DIYER
614
Rep 5,521
That sucks lol! I would still like to!
