Quietest aftermarket exhaust
07-16-2013, 03:08 PM | #1 |
407
Rep 2,704
Since I have the stg 2 turbos coming
I should probably upgrade the exhaust. Which one makes the least noise possibly with high flow secondary cats? So from the dps back Thanks |
07-16-2013, 03:22 PM | #5 |
Rep 1,079
Do you also shed most of the factory weight?
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
07-16-2013, 04:18 PM | #9 |
Rep 3,004
Not sure if you have an E90 or E92, but I find the 2007 stock exhausts on the E92 sound great. I think they made changes to successive years and made them quieter, so if you have 2008+ and later E92, try to source a 2007 E92 stock exhaust and if you want it louder, just cut out the secondary cats and weld in a straight pipe. Will be much cheaper and will not have the drone that many aftermarket exhausts have.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
07-16-2013, 04:23 PM | #10 | |
407
Rep 2,704
Yes the exhaust is nice at wot with the castles downpipes. I just like the no drone at cruise. But with new turbos coming I would like to push more volume through like three inch piping mandrel bent with maybe like 200 cel count cats just to kill some smell. Do you think keeping the stock mufflers creates any substantial restrictions ? So 3 inch pipe from dps with high flo cats but keeping the muffs? Ideas |
07-16-2013, 05:49 PM | #11 |
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
HKS has an amazing exhaust. Definitely in my future.
07-16-2013, 09:50 PM | #12 | ||
Rep 3,004
07-16-2013, 10:16 PM | #13 |
Rep 3,004
Agreed, every car I have heard with an HKS piece always sounded great, can't speak of the drone though.
07-16-2013, 10:22 PM | #14 |
2095
Rep 43,350
Our 3.5" exhaust shaves just over 40lbs of weight and has little to no drone in comparison to the other guys. Here's a few videos:
http://www.youtube.com/results?searc...q=vrsf+exhaust |
07-16-2013, 11:33 PM | #16 |
Rep 3,732
Drives: BMW S1000XR
I have never used them but I give my vote to VSRF for a tame exhaust based on a lot of vids. Dinan and the PE get a bit loud as well as some of the others. I prefer a little more sound, the wifey doesn't, so I bought the BMW PE.
BMWCCA member |
07-17-2013, 04:39 AM | #17 |
Rep 7,377
just keep the stock setup with catless dps. if you want more flow you can weld some race 100 cells cats as i have done. best sound and emissions are in check at least where i live.
07-17-2013, 08:25 AM | #18 |
Rep 942
I have an '07. July '07 build to be exact. I did a HKS and it was about as loud as I wanted, but still too much for Daily Driver use on 8+hr trips. So I sold it and bought another '07 factory exhaust from a local member. I am really surprised how loud the stock exhaust is. With the golf tee mod it's "perfect" to me. There may be some truth to the later models being quieter.
'07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, Macht Schnell Downpipes, 18" Staggered 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Dinan Oil Cooler, Dinan Intercooler, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Blend V1 mount, Llumar ATR Tint.
07-17-2013, 06:10 PM | #20 |
Rep 3,004
You shouldn't throw codes with your secondaries removed. If you search around I know someone opened up secondary cats and it was only filled with like what appeared to be sound deadening type material.
But if you have a tune, it should be able to remove any possible CEL's, but you should be good to go assuming you have your primaries installed.
07-17-2013, 06:31 PM | #21 | |
Rep 1,392
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
07-17-2013, 06:54 PM | #22 |
Rep 3,736
+1 stock exhaust will suffice
