Installing a FMIC
07-17-2013, 12:02 PM | #1 |
1250
Rep 1,502
Installing a FMIC
I had the pleasure of installing my FMIC twice this week and here a few pointers I learned through both processes that may help future first timers with the install. Put your flame throwers away:
1. Wash the silicon couplers in dish soap to remove any surface oils and dry them with a lint free cloth. 2. Use Acetone or Brake parts cleaner on all pipes and intercooler to remove any oil blowby or grease. 3. Position your clamps on the couplers before installing them. 4. Spritz the couplers with strong hairspray to help them slide on and to help seal them. 5. Take note of where the beads are on the pipes and take time to position the couplers so the clamps will seat behind the beads. 6. A driver with a flex joint and deep socket will make quick work of the clamp tightening, but do the final tightening by hand. 7. Tighten your clamps until they are very tight/difficult to tighten any more. 8. When installation is complete, wait 30 minutes to allow the hairspray to cure before going for a test drive. Usually by the time you are done cleaning up you're about ready to go. My first installation was easy, but I didn't wash or degrease anything. In fact, i wiped a little moly grease on the couplers to help them slide on. As you would guess I had boost leaks everywhere. After some research online on diesel truck forums (where guys are running 40-80 lbs of boost) I realized I made mistakes and decided to just redo the install the right way. Now I have no boost leaks; go figure! Nothing I listed above is revolutionary, and most install guys know these tricks, but for newbies it should prove helpful.
2011.5 E90 M3 DCT ZCP Slicktop
07-17-2013, 12:39 PM | #2 | |
3441
Rep 79,211
07-17-2013, 12:54 PM | #3 | |
2095
Rep 43,350
Great tips, definitely going to refer future customers to this
Thanks for taking the time! Quote:
07-18-2013, 03:28 PM | #6 |
3441
Rep 79,211
07-18-2013, 03:33 PM | #7 |
El Capitán
521
Rep 2,652
