Ordering a ProTune
07-17-2013, 02:03 PM | #1 |
123
Rep 1,503
Ordering a ProTune
I'm almost full bolt on now minus a few things. I am really interested in a protune by PTF but I just had a few questions before I order it. I have catless downpipes, 7" fmic, dual cone intake, and a cobb ap as of right now. The VRSF FMIC came with an "upgraded chargepipe" because my car was a 2010 model. When selecting my mods for the tune, should I select chargepipe as one of the bolt on mods or just leave it blank? Help would be appreciated.
Thanks, John |
07-17-2013, 02:09 PM | #3 |
Rep 510
+1. The aftermarket CP is just supposed to handle higher levels of boost without cracking. Won't influence the tuning of the car (assuming it doesn't crack with the higher boost levels ofc..)
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
07-17-2013, 02:10 PM | #4 |
2095
Rep 43,350
The lower charge pipe provided for 09+ models is more of a fitment/install deal, not necessarily a performance modification. Although it will outflow the factory lower chargepipe, the gains are very small due to the short path.
When PTF asks for the chargepipe, they're probably referring to the upper chargepipe which goes between the lower charge pipe & your throttle body. |
07-17-2013, 02:23 PM | #5 | ||
123
Rep 1,503
07-17-2013, 02:35 PM | #6 |
50
Rep 1,677
Drives: 14' GMC Terrain SLT-2
AT or MT
if your AT I highly recommend placing the Kick Down Spacer between the gas pedal and the floor. You will be doing a lot of 3rd Gear pulls, well worth the 5 min.
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
07-17-2013, 02:48 PM | #7 |
Rep 6,478
Yes. Such a PITA to ruin a log or pull with that stupid kickdown switch. And it takes like 10 minutes of total effort to do.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
