cobb P30FF only under WOT
07-19-2013, 12:57 PM | #1 |
Rep 79
I have a Cobb tune on my car and everytime the past few days I go WOT I get the 1/2 engine signal. I just had my coil pack replaced, but this did happen from time to time before the service was done. Now it is everytime I go WOT. I have 80k on my car so I checked the vacuum tubes going over the engine block and they looked ok from what I could tell. I did not know if anyone has had this problem under the same conditions as me and could give me a strarting point. Any ideas would be greatly appreciated. I know the code is related to vacuum system from what I have serched on the forum.
I hooked up the access port and monitered the boost. Sitting still and declerating I show -neg boost numbers is this normal. Sorry for all of the noob questions. This is the first turbo car I have ever owned. Most of the rest were all LSX powered.
2007 335i sport sedan fully loaded, fmc, downpipes, PTF custom tune. Sold
2012 X5 50i fully loaded. ESS TUNE 2017 X5 M Donington Grey |
07-19-2013, 01:01 PM | #2 |
3441
Rep 79,211
Looking ok is not the issue. Just replace them you have too much mileage on them as it is. They should have been replaced at 50K as regular preventive maintenance.
Nobody here can tell you what is leaking. You need to start inspecting or replacing items thoroughly. Vac Lines Tighten Clamps Pressure Test System Boost Solenoids Sticky wastegates ETC I just wrote about 6 paragraphs in another thread about 30FF. Check it out. Negative boost is normal at idle. |
07-19-2013, 01:10 PM | #4 |
Rep 79
Thanks for the info. I will try to find a shop.
I am sure the lines were replaced at 50k since the CPO just ran out and I am the second owner. I will replace them anyway with the silicone ones.
