Speaker configuration
07-21-2013, 10:43 AM | #1 |
Rep 8
Hello everybody from Spain, I'm thinking about the audio project for my E90...
I have the BMW professional HU. I have two amps: -JL Audio XD600/6: 6x75wrms -Alpine PDX f6: 4x150wrms I'm looking for a speakers: -2 separate ways front door speakers (amp with XD600) http://www.type-rsound.com/p/4508/audio-system-x100bmw or http://type-rsound.com/p/5103/dls-up4 -Coaxial Rear door Speakers (amp with XD600) http://www.type-rsound.com/p/4244/audio-system-co100bmw -2 separate ways Rear Speakers (amp with XD600) http://www.type-rsound.com/p/4251/audio-system-r100 -Underseats speaker (amp with PDX F6) MID: http://www.type-rsound.com/p/4279/audio-system-ax-08bmw or SUB: http://www.type-rsound.com/p/4509/au...m-ax08bmw-plus -Trunk Sub (amp with PDX F6) http://www.type-rsound.com/pm/2028/jlaudio-10w3v3-4 I want to make something like this: http://www.e90post.com/forums/showth...ight=Xd600%2F6 What do you think about? Any recomendation? -Is better to replace the rear door speaker or install a central speaker amp with the XD600?? -Do you think is enough with under seats MIDs or much better a SUB?? Thanks. Last edited by MAD; 07-21-2013 at 10:53 AM.. |
07-21-2013, 11:37 AM | #2 |
1926
Rep 13,134
As far as the links go "No habla espanol" at least not good
As far as the links go "No habla espanol" at least not good.
Looks like the first speakers fit and the second one ups need adapters. Read this first http://www.e90post.com/forums/showthread.php?t=641323 Its important to establish which system you are starting out with. If you have the stereo system as oposed to Hi Fi or L7 what you do will be different. If you are starting out with the stereo system you need to get a frequency flattening device of recode the output of the Head Unit to Hi Fi. Getting this done and a harness should be first on the list. Most say don't spend a lot on the rear seat speakers. BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=343673 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/showthread.php?t=641323 http://www.e90post.com/forums/attach...1&d=1209780865 http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...4&d=1278871872 |
07-25-2013, 12:01 PM | #3 |
Rep 8
Thanks for all the information.
I have the stereo system. I was on a caraudio shop, I want they install everything...then they told me that they have to install a high to low signal converter to get the RCA from the HU. Something like this: http://www.rockfordfosgate.com/products/details/rf-hlc4 I want to use both amplifier then I think the following: XD600 will amplifier: Front doors: 2 separate ways Audio System X100 (Installation with 3 bolts ) Rear doors: Coaxial Audio System CO100 (Installation with 3 bolts) Rear: Stock Speaker PDX F6 will amplifier: Underseats speaker: Audio System AX 08BMW (Its a woofer 80rms) or Audio System AX08BMW-PLUS 150wrms (It's a SUB like SWS-8) Optional, Install a JLAudio SUB on the trunk. Then the question is: Install a 8" Wofers + trunk SUB ? Install a 8" SUBs ? (Then I will have 2 PDX chanels unused) Install a 8" SUBs + trunk SUB ? Thanks, Last edited by MAD; 07-25-2013 at 01:32 PM.. |
07-25-2013, 06:56 PM | #5 |
1926
Rep 13,134
If the 8 inch speaker fit in the underseats.
If the 8 inch speaker fits in the under seats.
You might just want to do that first and see how it sounds. If its still not enough bass for you then add a 10 inch or bigger trunk sub and a nice enclosure of some kind. If you are a total bass head you will probably want the trunk sub. |
